Results 1 to 9 of 9
Thread: M16 LEFT-HAND Thread Tap and matching High Tensile Bolts
    Mar 2010
    Queensland
    12.97 MB
    Hello All,
    I walked in to the local bolt suppler and asked them if they could supply an M16 LEFT-HAND thread tap and two matching thread pitch high tensile bolts. They looked at me as if I was fitted with more than the standard number of heads. Then they abruptly said, "No way. Good luck trying to find any!"
    I have since sent a series of emails to Australian nut and bolt suppliers to see if the items are available here in Australia.
    Just in case I also searched for any overseas-based suppliers. The only difficulty finding overseas suppliers seems to be finding one mob that sells both the tap and the bolts. Plenty of business seem to sell one or the other.
    I did not think that it would be so much of an effort to source such items! Hopefully the 14.5 mm diameter drill bit will be easier to buy!
    Have you had similar issues buying left-hand thread taps and bolts?
    Kind regards
    Lionel
    Narre Warren South
    Lionel,
    Is the bolt from a vehicle ?
    When vehicles are mass produced the manufacturer can specify whatever they want, they are vehicle specific.
    On the Isuzu in my SWB the flywheel bolts are HT M13 x 1.25 and shouldered, Isuzu is the only place you can buy them.
    You say M16 but what pitch ?
    Plenty of taps on Ebay but as you were told 'best of luck trying to find bolts'.
    M16 X 2.00mm X 40 Metric Left Hand Thread Bolt Grade 10.9 ( 1 PC) | Left Hand Fastener
    Colin
    '65 Series IIa Dormobile
    '70 SIIa GS
    '76 SIII 88" (Isuzu C240)
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
    Jun 2008
    Drouin East, Vic
    These are one of the few things I would buy off eBay; I just typed 'M16 left tap' into eBay and came up with a number of options, followed by 'M16 left bolt' and again numerous options. Just avoid the chinese sewerage outlets; if the seller's 'other items' include totally unrelated crap, avoid them, whereas sellers who specialise in industrial supplies are usually ok.
    Dec 2008
    Tewantin, Qld
    Hi Lionel,
    x2 for the Flea Bay.
    If you are after a specific bolt size and tensile strength (as opposed to a machine screw) you might be better getting a die as well, buying a longer RH bolt and threading that.
    I've had similar problems with BSF.
    Cheers Glen
    Narre Warren South
    Quote Originally Posted by Dorian View Post
    Hi Lionel,
    Cheers Glen
    Best of luck running an Ebay die down a HT bolt.
    Colin
    '70 SIIa GS
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
    Nov 2011
    East Gippsland
    Tracy Tools in Devon have LH M16 taps and dies in 1mm, 1.5mm and 2mm pitch.
    LEFT HAND THREAD - METRIC
    I have heard good reports about teh quatity of their taps, but not cheap.
    They also have M13 taps and dies.
    Peter
    Apr 2019
    A nut and bolt shop isn’t the best place to start….
    Try these guys in Brendale (Brisbane) , I used to buy a bit off gear off them, taps, dies, cutter, measuring equipment.
    Welcome to Advanced Tooling Supplies - Advanced Tooling Supplies
    Narre Warren South
    Quote Originally Posted by pedro54 View Post
    Peter
    I used Tracy Tools regularly when I lived in the UK.
    They used to have a lot of NOS taps & dies, I still have a BA set I purchased from them with taps down to 11BA plus BScy & BSF.
    Colin
    '70 SIIa GS
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
    Jul 2011
    Yarrawonga, Vic
    Why do you want the left hand thread bolts anyway ?
    Btw its just as easy to make left hand threads on a lathe as it is right hand threads, Any machine shop can make any bolt any size any pitch.
