Results 1 to 10 of 15
Thread: Help ...key fob won't unlock immobiliser.
    May 2010
    on the road
    Key fob is sending a signal but receiver( on car) not picking it up . So wonÂ’t unlock engine imobilizer. Any ideas... cars parked at the r.s.l
    auto electrician trying to help ..
    Can the imobilizer and alarm be turned off in the software and just open doors and start motor by turning the key?
    is the receiver back left hand side of the car?? In near the sub woofer ?
    new battery in car and key fob .
    could it be dead locked .... if so what do you do?
    P38 1999 4.6 Thor motor (1999-2002)
    thanks Paul
    Jan 2016
    Netherlands
    Turners Garage - P38 BeCM Unlocking
    I know of at least one company who can do that but you would need to remove the unit to do so and if the car is superlocked, that could be a problem...
    The receiver should be in the back, yes and some models have been known to go bad.
    Other than resyncing the key, maybe it went out of pace after too many tries? I am not sure at this point.
    -P
    Oct 2007
    Williamstown, Victoria
    As Prelude said, try re synching the key before you do anything else.
    Are you are seeing the red light on the remote when you push the button?
    If not, you might need to clean the battery contacts inside the remote, or a new battery.
    If the red light comes on, put the key in the drivers door lock, push the unlock button, let go, and then turn the key and see if that works.
    Try to avoid pushing the lock button multiple times, as that might put it into a superlocked state.
    If that does not work, try again and see if any error messages appear on the message centre.
    That might give you a clue as to whats going on.
    I have had issues where if I'm parked near a mobile phone tower or other electrical fields, the remote struggles to unlock the car.
    To get around that, I put the remote close to the petrol filler opening, or around the rear and other side in the same area which usually unlocks the doors.
    Let us know how that goes.
    Pete.
    May 2010
    on the road
    Quote Originally Posted by prelude View Post
    -P
    thankyou .... pls let me know the name of the company that can do that work.
    cheers Paul
    May 2010
    on the road
    Quote Originally Posted by PeterH View Post
    thanx Pete .tried your idea with putting the key in the door and pressing the unlock button and Walah it worked !! Drove home , and same thing didn’t work next 3 times , then worked twice . Next 2 times fob opened doors and turned off the demobiliser.
    maybe I change the receiver?? Wonder where I would get one .?
    like a lot of p38’s doors unlock and lock randomly .... maybe I need to replace all 4 door modules also??
    appreciate your time . Thanx
    paul
    Pete.
    thanx Pete ,
    Jan 2016
    Netherlands
    What I wrote included a link: Turners Garage - P38 BeCM Unlocking it is the website of a company who does this kind of work. There also seems to be one down under! BECM Programming I suggest you give them a call after all other alternatives have been exhausted of course since this is kind of a big step to take and if the cause of the problem is not fixed, it will return no doubt.
    -P
    Feb 2010
    3029 Melbourne
    If you can find someone with nano com you can get into Becm options and switch off alarm & disable EKA this will allow you to lock unlock doors by key & start engine
    This works on aus delivered & configured vehicles as I did this with mine!
    Oct 2022
    Adelaide
    Had this happen to my car (2000 model) last week though the problem had probably been building for a couple of years (locks activating on/off whilst driving etc) This time the key fob wouldn't work and immobiliser wouldn't disengage either: broke down less than 20metres from my driveway entrance.. I managed to deactivate/reset the immobiliser by turning the key to the unlock position 2x and then pressing the unlock button to resync the key etc: it worked. Alas, once reparked in the driveway the immobilisation problem returned. At the local breakers I was advised 'they all do this in time, Sir' and told to replace the door lock actuator on the drivers side. Was a fiddly job but manageable and the issue seems to be resolved. In the process I have also discovered how badly worn the door handle mechanisms are and so have ordered kits to refurbish them. If you plan to replace the actuator (not cheap but a fairly essential task from what you've described) then it may be as well to have the kits available to refurbish the door handles, i.e. a camlock kit and probably the main part of the handle too (really poor design; plastic on plastic..)
    HTH
    AndyW
    Oct 2007
    That's great Paul, I'm so glad that got you out of trouble!
    It's a nice feeling to hear the doors unlock after having dramas like that.
    My door locks used to lock and unlock randomly, (also known as chattering), which is not ideal when your Rangie unlocks itself in a car park.
    It's annoying when you are driving, specially with passengers asking whats going on with the doors!
    I replaced the drivers door latch mechanism and all has been great since then.
    Not a hard job to do, just a bit fiddly in the confined space, but quite doable yourself, no special tools required.
    It could also be the cause of your troubles, I would definitely do that first before trying anything else.
    The micro switches in the latch wear out and start playing up.
    There are you tube videos explaining the repair, personally I wouldn't bother trying to repair it, I just put a new one in and have not had any problems since.
    If you still have issues after replacing the drivers door latch mechanism, I would suspect the key fob first before the receiver, if you think about it, the keys get dropped and knocked around, it's amazing they hold up as well as they do.
    Do you have a second key fob?
    If not please get one asap, don't rely on one key, that is asking for trouble.
    Lee at LAB electronics is the man to contact, he is a genius with that stuff, he can repair your key fob and supply another working fob programmed to your vehicle.
    Keep us updated on your findings,
    Hope that helps, Pete.
    Feb 2010
    Townsville, QLD
    YES you can!
    G’day mate,
    I’ve not read all of the responses thoroughly as yet, but I can’t see anyone directly answering your question either.
    To answer your question -
    Can you disable the immobiliser on the doors and just use a key?
    YES!
    This is done by disabling via a Nanocom or the like. I have done this when my key batteries died, in order to prevent issues with the immobiliser until I could replace the battery. It will allow you to drive the car still until it’s all fixed.
    If the immobiliser is disabled can the superlock still be used?
    YES!
    This is done by turning the key back (anti-clockwise) a second time when locking the doors. Note: You will need to turn the key twice clockwise to remove the superlock.
    The tailgate operates off the lock command to the drivers door, so if it’s locking and unlocking by itself, the tailgate lock is doing the exact same thing. That’s a trap for young players 😝
    In the event that the drivers door locks itself, look over at the passenger door, it’s likely that it will not be locked, should you be experiencing the door lock chatter. This will allow you to enter the cab if you’ve left the keys inside.
    Keithy
