Results 1 to 4 of 4
Thread: No fuse holder…..
    Apr 2019
    No fuse holder…..
    No worries……things ya fine when pulling a motor
    Brisbane,some of the time.
    Could be worse,that is no fuse at all,or fuse with a much higher rating.
    Apr 2012
    Whyalla, SA
    In some instances I’d say that’s a good solution.
    Apr 2019
    Hmm, yes and no, at least they tried.
    While I didn’t think to check which side of the fuse was the power side, good chance who ever installed probably didn’t think about it. Maybe the insulated terminal was on the power side, maybe it wasn’t. Fuse was floating around maybe 10-15mm from the metal enclosure.
    And, the fuse was at point of use, the battery was around 2m away with the cable gong through 3 sheets of metal.
    No fuse holder….. No fuse holder…..
