Results 1 to 10 of 12
Thread: Main battery performance causes random codes?
    Apr 2007
    Newcastle NSW
    Hi all
    Been chasing random faults with rear door latch, suspension fault, transmission fault........
    Could an under performing main battery contribute to this issue? No Gap tool to interrogate. Only a OBD2 reader. Supercheap sale on at the moment.
    Goldey
    Just arrived: 2012 D4 3.0 HSE, the journey begins again ;-).
    Gone: 98 Disco 300tdi Auto, and some extras
    Dec 2014
    Townsville
    Possibly! I had a 6 mth old main battery drop a cell (as it turned out!) in the back of nowhere. The vehicle kept dropping into neutral and throwing up all sorts of faults on the dash. The Gap tool was awash with faults, in hindsight mostly electrical.
    I limped to a roadhouse and called for help as I didn't want to get stuck in a more remote place. We got a tilt-tray truck ride some 300 km to home base. Dud battery replaced under warranty - all good!
    Jun 2008
    McMinns Lagoon NT
    Quote Originally Posted by goldey View Post
    Hi all
    Goldey
    From my experience - Yes. Transmission fault was the main one although I did have a door lock do that with the last battery that was failing. HTH.
    Cheers, Dale
    'The D3' - 2006 TDV6 HSE
    Previously Enjoyed:
    2000 D2 Td5 - plus!
    josh.huber Guest
    Someone nearby with a gap can read off the codes mate, only need additional license for additional work. If you have someone nearby you can pay the additional $150 to have your licence added to their tool.
    Door lock would likely be age, the rest of us are all changing them these days,
    Suspension fault could be just a blocked drier or something more serious
    Transmission fault can also come up for an engine fault, as in the input torque is low so the transmission gives off the light first, I've had that.
    The dead battery does get involved at times with the last two
    Jun 2008
    McMinns Lagoon NT
    Quote Originally Posted by josh.huber View Post
    Experience leads me to differ with you as the FLH started not unlocking with the fob along the Tanami in July and after a battery change due to failed starter battery when I got home it hasn't skipped a beat since.
    Cheers, Dale
    Previously Enjoyed:
    2000 D2 Td5 - plus!
    Feb 2022
    QLD
    I've had transmission faults, epb faults, and others I can't remember when the battery is low... Nary a one since going to a dual battery system and making sure I have at least one battery under 3 years old... Its only my experience, but I'm very confident that a low battery generates a ****load of errors in these vehicles... (or, at least, it's the first thing I'd check before chasing other issues, based on personal results.)
    Apr 2007
    Newcastle NSW
    Thanks all
    Bit the bullet and bought a new Century DIN85LH AGM from Supercheap (on sale $369, not bad given it's got 36 mth warranty and almost identical specs as the old Varta coming out of the car).
    As I don't have a Gap tool or access to one, can I do a hard reset prior to installing the new battery? Steps I've seen on the net for battery replacement are:
    1. close the doors and wait for a few minutes for the screen and lights to disappear inside the vehicle;
    2. disconnect the auxiliary battery negative, then positive;
    3. disconnect negative lead off main battery;
    4. disconnect positive lead off main battery;
    5. Remove main battery;
    6. Hold the negative and positive leads together for at least 2 minutes (this I assume is the hard reset where any residual voltage is removed from the collection of ECUs);
    7. Install the new battery in reverse order as above;
    8. Reinstall the aux battery arrangement in reverse order (ie positive first then negative).
    Can anyone see any issues with doing this?
    Goldey
    Brisbane,some of the time.
    FWIW,random codes are thrown up by lots of different brands of vehicle with faulty start batteries,or batteries with low charge.
    Jun 2008
    McMinns Lagoon NT
    Thanks all
    Goldey
    Above my paygrade sorry. My D3 only requires the clock on the radio to be reset after a new battery.
    Cheers, Dale
    Previously Enjoyed:
    2000 D2 Td5 - plus!
    Mar 2016
    Thanks all
    Goldey
    A hard reset won’t do anything to avoid you needing a gap tool. It doesn’t tell it it’s got a new battery. The vehicle knows how many batteries have been fitted and records it (if you follow the reset process using a diagnostic tool) and when you reset it, it resets the charging process
    2007 Audi RS4 (B7)
