Results 1 to 8 of 8
Thread: Wheel Alignment in Perth
    Nov 2022
    Red face Wheel Alignment in Perth
    OK 2nd post...already
    I need to get a wheel alignment done on my 2012 RRS 3.0 TD. She pulls slightly left. Are there any recommended places to go, where they know how to do an alignment correctly for these cars and actually end up with the steering wheel centered as well?
    Oct 2011
    Fremantle WA
    Quote Originally Posted by WestOz View Post
    Tyrepower in Scarborough Beach Rd near Barbagellos gets a good rap for LRs - I go there
    Mar 2018
    Perth (near Malaga)
    Second Gav's recommendation. When I dropped it in I put it in TTM and turned it off when I picked it up.
    It's the first time in 5 years it has tracked properly.
    Nov 2022
    Quote Originally Posted by BradC View Post
    Excuse my ignorance but what does TTM stand for?
    Jan 2015
    Tight tolerance mode. Decent explanation in this thread, amongst others:
    TTM - refused to do it this way?
    David
    Everything is easy when someone else is doing it
    MY14 SDV6 SE Corris Grey
    Compomotive 18s : D697s : Traxide DBS : LLAMS : ARB compressor : IC-455
    Rhino Platform : GOE compressor, Tx & front bash plates, deluxe sliders
    Nov 2017
    West of Perth
    I use Tyrepower Perth City, which is actually in Troode St, West Perth.
    Same deal: I drop it off and put it in TTM with my GAP tool. They do the job - very well! And I collect it an hour later, pop it out of TTM and off I go.
    Around $100, IIRC.
    If at first you don't succeed, that's one data point. - xkcd
    2011 Discovery 4 SDV6 HSE
    Nov 2022
    Well I solved 90% of my wheel alignment issues by adjusting the ride height to spec at each wheel using the GAP tool and its very handy built in procedure. After a couple of goes, with a drive in between, to get it as close as I could, the slight left pull is significantly less and possibly not at all as she will go straight if carefully aligned. But perhaps the steering is a bit twitchy and an alignment will help with giving her a better track.
    Getting back to the TTM, do I understand correctly that the car needs to be running when TTM is set and left running for TTM to continue to operate. TTM is shut off if the car is shut down. Is that right or does TTM stay on until shut down again via the GAP tool even if the car is stopped and restarted again?
    Nov 2017
    West of Perth
    It stays in TTM, even with ignition off, until you set it back again.
