Results 1 to 8 of 8
Thread: Old Series Glass and Metal front lights on Defender 110
    Mar 2010
    Queensland
    12.97 MB
    Hello All,
    Being new to a Defender 110 would the reproduction glass and metal front lights for a Series Land Rover fit into the Defender's front panels? Are the lights roughly all the same diameter between say a Series 2A and the Defender 110?
    When I was working on Snowy's parking lights and indicators the plastic around the bulb holders disintegrated. Back in 2012 I had brought some modern replacement generic all plastic lights - front and rear - for a couple of Series IIIs - only to find that their bases were either cracked or broken. The boxes they arrived in were in perfect condition so the lights had not been crushed in the freight. I had to place a new order and the retailer supplied a different also unnamed brand. I think the retailer was sold a batch of dud lights from the manufacturer.
    Having learnt from this lesson I figure for now I might go the opposite direction in time and revert to the original combination of metal bases and glass lenses. It is only four lights for the front. Snowy's tray has the bog standard Narva rectangular combination lights fitted to it that are in good conditions - so they will be staying put.
    Kind regards
    Lionel
    Narre Warren South
    The metal & glass ones are very expensive if you can find them, you might get replicas from the UK otherwise you are looking for old stock.
    Here's an example from the UK at just over 23GBP
    Lucas L488 Type Flasher Lamp - Single Contact
    On Ebay but maybe plastic lens ?
    2 x Universal Lucas Style White indicator Lamps Lights CLASSIC MINI /KIT CHM13WZ | eBay
    I'm reasonably sure they are the same size but I've never had to remove my Defender ones.
    I fitted the ones with plastic bases to Wallit, indicators OK but the sidelight lenses have yellowed.
    If you can find the old metal backplates & glass lenses then the rubber housing is available new. I'm sure Scotts Auto Rubber used to have them.
    Colin
    '65 Series IIa Dormobile
    '70 SIIa GS
    '76 SIII 88" (Isuzu C240)
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
    The Series and Defender (at least up to 2007) panel openings are the same, I am pretty certain. although I have not actually tried what you are planning.
    Quote Originally Posted by gromit View Post
    Scotts is now Old Auto Rubber and is in Penrith. I go past them occasionally.
    Mar 2010
    Queensland
    12.97 MB
    Hello Colin, John, and Ron,
    Thank you for your replies and for your insight. I am aware that the glass and metal lights are expensive. I intend to hold on to Snowy for quite some time so the investment will hopefully be worth it. When I went to refit the bulbs after taking the mudguards off for dent repairs, I found that quite a few of the bulbs jumped straight back out because their plastic posts were unserviceable. I had previously been burnt by the all plastic replacements. I am hoping that the old saying "that you get what you pay for" turns out to be correct. Also, that I am not going to be a further contributor to Ron's "Propensity ..." thread.
    Kind regards
    Lionel
    Narre Warren South
    Quote Originally Posted by Lionelgee View Post
    Kind regards
    Lionel
    Lionel,
    Do you intend to store it outside or under cover.
    My Defender still has the original lights but to be fair it's spent a lot of time in the garage.
    Whether you can source 'genuine' replacements or not I don't know.
    Good plastic ones and the car stored undercover would be OK. Problem is without seeing them physically you never know what you are buying.
    Buying from overseas it's harder to return but mostly it's exactly the same parts as you'd buy locally without the Australia Tax but with a bigger freight cost. Typically cheaper overall.
    Colin
    '70 SIIa GS
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
    Mar 2010
    Queensland
    12.97 MB
    Hello All,
    The Lucas clone L594 glass lens with metal bulb holder-bases for a front set of indicator and parking light units arrived from the UK today. Plus, another order I placed on a set of OEM older L369 glass lenses that I bought in Australia arrived today. I saw the OEM L369 lenses on eBay. They were being sold as one of those 'Bid on' items, with no 'Buy now' price. I set a reasonable limit. I was the only bidder and got them for only $10 AUD for a pair of lenses - so that was a major win. The OEM L369 lenses came in their original boxes! The reason I bought the OEM lenses is to make-up some missing parts from a front set of original L369 lamp indicators that I took off of a Series wreck. One of the glass lenses was broken. This broken lens unit also had its base totally eaten away with rust. The other remaining unit was just dirty - but otherwise was in very good condition. The amazing thing was that when I went to take the bulb out of its holder the system operated like it was made only yesterday. The new lamp units I bought from the UK have a very similar feeling of being made of good quality materials when handling them - including removing and fitting the bulb. I am about to buy two new rubber boots and one new lamp holder from the Australian retailer so that I will have a complete front set of indicators for another project. Since the OEM L369 lenses came as a pair, I will have one for a spare.
    I bought a set of new light background panels and the new L594 lights look exquisite on them. I am very happy with them so far. It is so good to feel the bulb pins lock securely within their metal housing - not the feel of the of cheap plastic crap bulb holders that allow the bulbs to eject after you attempt to fit the bulb. The test will be when the crimp tool for the Lucas style 4.7 mm bullet fittings arrive and I get to make original looking wire extensions. This will allow all the indicator, side repeater lamp and the parking light wiring to be made much more easily accessible from behind the headlight. I am not very fond of having to be a octopus contortionist like you have to be now when attempting to hook all the wiring together in the far darkest and depths of the mudguard.
    The photos show a mix of the light units and the OEM L369 lamp lenses and the whole L594 units. All lenses are all the lights pictured are glorious glass that have colours that will not fade.
    I bought the lamp units off a UK supplier with postage who sold them for less than half the price of an Australian supplier - for most likely the very same units. In an effort to replace the all plastic side repeater lights I bought a set of Jaguar ones that have a nice chrome bezel. All the new lights will be the best looking part of Snowy my 1993 Defender 110 tray-back ute.
    Kind regards
    Lionel
