Results 1 to 10 of 23
Thread: D4 air suspension shock absorber replacement
    May 2008
    Lobethal, SA
    Has this been covered? Couldn't find it in a search.
    I have just bought a 2009 D4 3.0 tdi with air suspension and the right rear shock absorber isn't working. Do I have to buy a whole new unit or can I just replace the shocker? Should I do the lot at the same time?
    Regards, Erik
    josh.huber Guest
    You can do the shock alone, but the complete strut is easier and probably cheaper.
    What do you mean it doesn't work
    May 2008
    Lobethal, SA
    At over 100km/hr, when going over bumps, it drifts off to the right. This is a little disconcerting when I get up to overtaking speed on our rain affected country NSW roads...
    May 2008
    Lobethal, SA
    So am I looking at $600 per corner?
    Apr 2012
    Whyalla, SA
    Quote Originally Posted by Erik BM View Post
    Source from the UK. Even with freight less than that.. about $500 per corner max
    St Helena,Melbourne
    4.28 MB
    I would do both rears as you are probably getting up there in mileage, as above buy then from one of the many UK suppliers.
    LRC9746 - PAIR OF REAR AIR SUSPENSION DAMPERS FOR LAND ROVER DISCOVERY 3
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    May 2008
    Lobethal, SA
    Thanks for that information.
    So these cheaper ones on ebay oz are not good?
    4x Front & Rear LH RH Air Suspension Strut for Land Rover Discovery L319 L320 | eBay
    $893 for a set of 4?
    St Helena,Melbourne
    4.28 MB
    They are likely cheap junk, stick with OEM which is BWI.
    1974 VW Kombi bus
    Apr 2012
    Whyalla, SA
    Going cheap parts on a LR is a recipe for unplanned breakdowns at inopportune times.
    NSW Far South Coast
    Eric BM
    I fitted those cheap ones to my D4 a couple of months ago.
    I was doing a round WA trip and my front shocks started leaking. Both of them. The oil from the shocks ruined the air bag seals and I ended up sitting in Carnarvon for 8 days while I waited for delivery from Melbourne. Thanks for that AusPost!
    The reason I bought the cheapies was so I could get them delivered quicker than from England???
    Also, the ones I'd fitted 50,000kms previously were from England and BWI, so I wouldn't put them up on too much of a pedestal!
    The cheapies looked to be as well built as the ones I took off, and have worked perfectly for the last 5-6,000kms.
    Time will tell.
    Trevor
