Your right, they should be off when it sees a trailer is there.
 Master
						Subscriber
						Master
						SubscriberOne for the brains trust.
My Disco 4 has a trailer switch in the back, it was already installed when I bought the car, in theory turn it on and the car sensors a trailer, as in light on dash and rear sensors turned off plus any changes to trailer control or any other electrical wizardry.
If the switch is off there is no trailer light on the dash and van lights don't play by the rules
If the switch is on the trailer light is on the dash and van lights works as they should BUT the rear parking sensors stay on which is really annoying when trying to concentrate on reversing the van into a tight spot with vague guidance from the cook
How do I get the rear sensors off without cracking the ..... and cutting the wires
Discovery 1 4.6, true trac front and rear, superior engineering arms,old tourer now bush toy
Discovery 4 3.0 HSE MY13 ECB Bull bar, winch, spot lights, aux fuel tank, Kaymar rear bar, duel wheel carriers, 18 tuff ant wheels 265/65/18 BFG KO2's for play
 Master
						Subscriber
						Master
						Subscriber Master
						Subscriber
						Master
						SubscriberDiscovery 1 4.6, true trac front and rear, superior engineering arms,old tourer now bush toy
 TopicToaster
						Subscriber
						TopicToaster
						SubscriberStrange behaviour for a D4 - without any aftermarket changes, plugging any trailer in should make the trailer lights work correctly. For LED trailers, the car just doesn't show the trailer icon on the dash, and the reverse beepers stay on.
Assuming you have the same type of switch I do, it is intended to fool the car into thinking a trailer with incandescent light bulbs is attached. Trailer light on the dash, no reverse beeper, and I believe a change to the transmission shift points / behaviour.
What are the trailer lights doing when the trailer is plugged in, but the switch is off? What type of lights does the trailer have? (LED or Incandescent?)
2010 TDV6 3.0L Discovery 4 SE remapped to RRS output, Alaska White, GME XRS-330c, IIDTool BT, Dual Battery, Apple CarPlay, OEM Retrofitted: Cornering lights, Door card lights, Power + Heated Seats, Logic 7 audio
 Master
						Subscriber
						Master
						SubscriberThe van does have LED, cant remember exactly what the lights were doing when the switch is off, haven't tried it for a long time but it definitely makes a difference as the lights work correctly with the switch on and don't with switch off.
The switch does everything it should except turn off the reverse sensors
 Master
						Subscriber
						Master
See the thing is the switch is there just to fool the car into thinking (knowing) the trailer is attached. The computer system then turns on the dash light, disables beepers, changes transmission etc. The switch doesn't cut power to the beepers or anything like that.
Hence my comment about it being weird - the computer knows to turn the dash light on, but not disable the beepers. Kinda half pregnant there...
Have you got an IID tool to change the CCF files?
You could always try resetting the whole car, by removing both battery cables and touching them together...
