2017 L320. Having a problem with my car not receiving key fob presses to lock/unlock car. Have replaced the rf receiver under the roof lining but still no luck. Have confirmed key fob battery voltage is good and signal being transmitted. Have confirmed power at the point the rf receiver plugs in.
Anyone know a good Brisbane autolec with good knowledge of landrovers who might be able to help?
Sorry. 2007 RRS tdv8.
Sorry Gary. 2007 RRS TDV8
My LR Indie uses DJ's and they've done work on my D2 and D3 which I'm happy with, but give them a call about your RRS.DJ Auto Electrics
Auto Electrician Services
5.05.0 out of 5(2)
Write a review
52A Randall St, Slacks Creek QLD 4127
Phone(07) 3290 2290
2005 D3 TDV6 Present
1999 D2 TD5 Gone
I had what sounds like the same on my 2007 TDV8. The locks would not activate with the remote, the only way to lock/unlock was the key insertion on the passenger side door. The problem was traced back to water ingress from a sunroof drain tube that in turn corroded a connection in the wiring located under the passenger side door sill. A relatively simple repair for both the locks as well as the leak.
Gary
2007 Range Rover Sport TDV8
Modified 1996 p38a HSE sold
Thanks all. Auto electrician's didn't want to touch it. So I pulled the trims off again on the passenger door sill and went digging in the loom for the 3 green/white spliced cables. Found - redid the join and all working again.
Thanks everyone for your help.
