Results 1 to 6 of 6
Thread: Leaky's leak
    Nov 2015
    Merbein
    35.44 MB
    Cool Leaky's leak
    Now that i am back home and finished trips in Leaky i thought it was time to look at his coolant leak. 2.5l in 1300Km. looks to be coming from just under number 4 exhaust port, head gasket by the looks. Is this a place they normally leak? I guess a retension won't fix it.
    PeterN
    70' 164 Manual Volvo 227,000miles play car. "Sven"
    2001 BMW R1150RT bike, 118,000Km "Bruce"
    2000 D2 TD5 Auto 329,500Km and climbing. "Leaky" (VK3JUG)
    2024 Dualcab Hilux work truck, 12,000Km.
    Sep 2010
    The Hills.
    152.79 MB
    You sure? TD5s usually let you know if you have HG problems...
    Your pic doesn't show the entire thing. That housing contains the oil cooler. The cooler is surrounded by, well, coolant. They usually cause an oil in the coolant issue, but maybe in your case the actual housing may be leaking. There are gaskets, and the housing could corrode if the car hasn't had proper coolant in it at some point. Might be worth a look before tackling a HG.
    If it is this, change the cooler while it's out.
    PS: I think the housings changed a little over the journey, but the principle is the same.
    ​JayTee
    Nullus Anxietus
    Cancer is gender blind.
    2000 D2 TD5 Auto: Tins
    1994 D1 300TDi Manual: Dave
    1980 SIII Petrol Tray: Doris
    OKApotamus #74
    Nanocom, D2 TD5 only.
    Sep 2010
    The Hills.
    152.79 MB
    Not the greatest vid, but you'll get the idea I think, in the first 30 secs.
    ​JayTee
    Nullus Anxietus
    OKApotamus #74
    Nov 2014
    Nirvana near Albany W.A.
    You'll need to pull the exhaust manifold, it is the screw in core plug that is leaking, not the head gasket.
    It's worth getting the manifold machined back to flat while it's off, also replace the studs and gasket.
    Sep 2010
    The Hills.
    152.79 MB
    Quote Originally Posted by discorevy View Post
    Yep, that too. I had forgotten that one. As for the manifold, I upgraded the studs at 4 and 5 to M10 I think it was. It had snapped three of them anyway, so why not?
    ​JayTee
    Nullus Anxietus
    OKApotamus #74
    Nov 2015
    Merbein
    35.44 MB
    I did the oil cooler a couple of years for a leak at the front, it's not leaking from there it's coming from above. I'll have to pull the manifold off to get a better look. The manifold has been machined not long ago but do need to upsize the studs. I hope it's the plug, do they come out easy or do i need to put a blow torch on to heat it up?
    PeterN
