Results 1 to 10 of 12
Thread: Noise When Turning Left
    Mar 2012
    Armstrong Creek, Qld
    My 2.7 D3 is making a strange noise, when I turn the steering wheel to the left, even slightly. It's a whirring/grating sound and only occurs when in motion. I've crawled underneath and there's no evidence of leaks or anything damaged or loose. Right turn is fine.
    I'm thinking steering box, but only occurring when moving seems odd to me.
    'sit bonum tempora volvunt'
    Sep 2010
    The Hills.
    152.79 MB
    Quote Originally Posted by Saitch View Post
    You checked for bandicoots?
    Seriously though, where is the noise coming from do you think?
    ​JayTee
    Nullus Anxietus
    Cancer is gender blind.
    2000 D2 TD5 Auto: Tins
    1994 D1 300TDi Manual: Dave
    1980 SIII Petrol Tray: Doris
    OKApotamus #74
    Nanocom, D2 TD5 only.
    St Helena,Melbourne
    4.28 MB
    No steering box in these so either the PS pump or the rack.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Mar 2012
    Quote Originally Posted by Tins View Post
    It sounds like RHS front. Because it only does it when moving, it's a bit hard to tell. The good woman did offer to drive the Landie whilst I was underneath, but I declined.
    Mar 2012
    Yea, sorry. I meant pump. If it's only noisy in one direction, then I'm thinking the pump, assuming it is valve operated.
    Sep 2010
    The Hills.
    152.79 MB
    Could be as simple as old oil. Our very own sierrafery comments about that here:
    Power Steering whine | Land Rover and Range Rover Forum
    ​JayTee
    Nullus Anxietus
    OKApotamus #74
    Sep 2010
    The Hills.
    152.79 MB
    She was probably singing the chorus of The Newcastle Song under her breath
    ​JayTee
    Nullus Anxietus
    OKApotamus #74
    Oct 2012
    Front wheel bearing?
    Apr 2012
    Whyalla, SA
    Quote Originally Posted by PerthDisco View Post
    You're likely on the money here!
    Mar 2012
    Unbelievable! I ran into the local auto leckie and mentioned about the noise, in passing and he said I should check for a stone/small rock between the cover plate and the back of the brake rotor, using a torch and a screwdriver handle to tap the plate. Bingo!
    He had the same issue on his Ranger. Took him ages to find it.
    We have had our road surfaced and it is still very pebbly, so am assuming I picked one up from there.
    As a bit of trivia, I found that a 50mm towball fits snugly into the rear chassis, jack hole and the concave top of my trolley jack!
