Page 1 of 5 123 ... LastLast
Results 1 to 10 of 48
Thread: Critical Spares Kit?
    Oct 2016
    Perth, AU
    Hi all
    There is a sticky thread that talks about an ideal 'kit' of spare parts to take along with you, should you go proper bush... We're planning a Gibb River Road trip in 2023, so this is now on my planning list.
    Land Rover in Cannington (Perth) previously had a kit they would lend out on a 'return or pay' basis, but no longer. Calling them, they did offer to refund any stocked items on return (ie, you buy them now, knowing you can return for a refund if not needed), however wheel speed sensors and height sensors for D4s are no longer a stocked item (!!), so that deal won't work.
    Does anyone know of any other place, maybe an indy, that has a spares kit available? Buying the various parts runs up quite a bill (even ex UK), and given you ideally don't need any of them, it feels a bit wasteful to purchase...
    I'm not thinking anything too crazy mind you - just front and rear speed sensor and height sensors really. I'll buy a fuel filter too, but that WILL eventually get used, so no dramas on that one, plus a fuse kit, which is cheap and useful elsewhere.
    2010 TDV6 3.0L Discovery 4 SE remapped to RRS output, Alaska White, GME XRS-330c, IIDTool BT, Dual Battery, Apple CarPlay, OEM Retrofitted: Cornering lights, Door card lights, Power + Heated Seats, Logic 7 audio
    BradC is offline Super Moderator
    No one of consequence
    Supporter
    Mar 2018
    Perth (near Malaga)
    I've given a lot of thought to carrying height sensors. I figure if one fails I can pump the thing up level using the GAP test mode and pull the suspension fuse.
    For LR specific I carry a spare brake switch, set of fuses (mini & standard blade, plus one of each fusible link), 2 brake light bulbs, a few 5W wedge bulbs and a couple of each external moulding fastener. I never thought the fasteners would come in handy until I hit a shrub and tore a wheel arch off. Used the contents of the kit plus a few cable ties.
    If going further than a couple of tanks of fuel I'll chuck a fuel, oil and air filter into the Van.
    I do carry enough tools to do an entire engine rebuild on the side of the road though. If I have them, I won't need them.
    Edit: I've never documented these before, so I figure photos will help.
    Spares :
    Glovebox tool kit (ex Hospital tool kit) :
    Tailgate / Boot tool kit :
    Under rear drivers side passenger seat kit :
    Mar 2016
    Much like Brad, I’ll use the GAP for most suspension issues.
    I do have a front and rear wheel sensor - OEM versions that I hope will work when I need them. A few spare bolts here and there, plus a brake switch. I need to get myself a fuse kit. Being a D4 I don’t bother with bulbs - rear is LED and front is xenon. Anything else that goes can be sorted - it’s just a bulb.
    I should add a fuel filter to my kit. I don’t bother with an air filter.
    Touch wood, all I’ve ever needed is tyres as I used to like taking out the sidewalls. I find it’s always something plastic on the engine that splits and fails on me, whether it’s a throttle body or manifold. Murphy’s law.
    2007 Audi RS4 (B7)
    350RRC's Avatar
    350RRC is offline ForumSage Silver Subscriber
    What about a wallet with lots of plastic, for those small issues and a jerry of petrol and a box of matches for the biggies?
    josh.huber Guest
    I have a few odds and ends, but the bigger items, wheel bearings etc, alternator. I leave here in a parts box, I figure by the time I find a workshop they will arrive by post. I have plenty of people who can come and grab them and mail them to me. Just a thought to keep weight down. For me.
    Multi metre, soldering iron and a bit of wire (mainly for the camper), basic tools, fuse kit, fuel filter, belt, gap tool. Manual, brake switch. I basically take really light petty stuff so I don't get stuck for something silly. If I fall a wheel bearing, alternator etc. I'll happily just wait for it to arrive
    I need to add height sensors and abs sensors to my at home stock. If I had them at home. I'd take them too.
    I keep an eye on gumtree, my wheel bearings And a few other spares where another man's traveling kit, got em cheap!
    Oct 2016
    Perth, AU
    Quote Originally Posted by 350RRC View Post
    I have that, but i don't always have time to burn - waiting a week or more for a silly part like an ABS sensor will still make a dent in a roving trip like the Gibb...
    Oct 2016
    Perth, AU
    Thanks for the responses all,
    I do also have a GAP tool, which will get us out of big trouble, but i'd prefer to be able to fix the problem, rather than 'MacGyvering' a solution that needs to last a month or more of rough terrain.
    I'll bolster the spare supplies with some electrical repair stuff, and see if I can order a few spares. That is one serious toolkit BradC!
    Are there many on here that have had a 'simple' part like height sensor or ABS sensor fail out in the bush?
    St Helena,Melbourne
    1.13 MB
    GAP tool for those you can diagnose and or tackle yourself, good phone coverage for the rest.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Sep 2010
    The Hills.
    152.79 MB
    Something less extreme perhaps?
    ​JayTee
    Nullus Anxietus
    Cancer is gender blind.
    2000 D2 TD5 Auto: Tins
    1994 D1 300TDi Manual: Dave
    1980 SIII Petrol Tray: Doris
    OKApotamus #74
    Nanocom, D2 TD5 only.
    Apr 2012
    Whyalla, SA
    Here’s the spares kit I’m taking for the next 2,200km trip…
    As laid out on the floor… Critical Spares Kit?
