Page 1 of 6 123 ... LastLast
Results 1 to 10 of 57
Thread: Defender 130 td5 engine cuts out
    Dec 2022
    My td5 Defender 130 (2002, 232,000 ks) runs and drives perfectly for about 15 minutes, and then the engine stops and the check engine light comes on. Attempts to restart it result in it firing feebly on 1 or 2 cylinders, but not enough to keep it going.
    Then, if I leave it for about half an hour, it suddenly recovers and drives normally until the next cut-out, etc etc.
    In my attempt to solve this problem I have put in a new fuel pump, a new fuel filter, and the two air bleed valves in the fuel filter connectors. All to no avail.
    Another symptom, possibly a red herring, is that the fuel filter gets very hot. I don't know if this is normal or not.
    Any ideas would be much appreciated.
    Kinc
    Sep 2010
    The Hills.
    152.79 MB
    Quote Originally Posted by MDAkinc View Post
    Kinc
    Failing crank angle sensor maybe? Or the wiring going to it? PITA to get at on a Disco but shouldn't be too bad on a Deefer.
    How hot? The fuel does get hot, they have a cooler for exactly that, but not too hot to touch in general.
    All a remote diagnosis guess, of course, but the crank sensor will throw the MIL on.
    ​JayTee
    Nullus Anxietus
    Cancer is gender blind.
    2000 D2 TD5 Auto: Tins
    1994 D1 300TDi Manual: Dave
    1980 SIII Petrol Tray: Doris
    OKApotamus #74
    Nanocom, D2 TD5 only.
    Jan 2014
    Perth Western Australia
    As Tins suggested crankshaft position sensor...
    *unplug it, spray clean it. (easy to get to on a Defender)
    *unplug the injector harness on the front of the engine, spray clean it (see how much oil is in the plug).
    *unplug the red plug on the ecu under the seat and spray clean it (again see if/how much oil is in the plug).
    Daz
    Sep 2010
    The Hills.
    152.79 MB
    Quote Originally Posted by DazzaTD5 View Post
    Thanks, you reminded me i have a new injector harness to fit.
    ​JayTee
    Nullus Anxietus
    OKApotamus #74
    Apr 2016
    further to the suggestion already mentioned:
    do you have access to a nanocom?
    If so, use the page that displays cylinder balances. Watch it closely at approximately the time where you think it'll cut out. If the cylinder balances go all haywire(from relatively stable values between about 0 to 5) .. I reckon your injector seals are gone, or on the way out .. and it'll probably just get worse.
    If you don't have a nanocom, the other thing you can test out is, when it cuts out again, do the routine where you bleed the injection system. On a D2 that is ignition on(don't start!) and pump accel five times rapidly, where it then actiuvates the fuel pump for a few minutes to bleed out the fuel lines.
    This may result in an instant start fairly quickly, or (more accurately) a less arduous start than you have at the moment. It may also result in a lot of smoke on start up if it does.
    I don't know the bleed routine for a Defender, but I'm guessing it's the same as a D2 TD5 too.
    If it does do this, you will see a warning light on the dash as well as hear a hissing sound as the pump bleeds out the injectors.
    What you described(and I suggested) is exactly what happen with my D2 when brother owned it and drove us crazy trying to sort it out, until the wise chaps here suggested injector seals.
    if you haven't done them at any stage, or don't know if they have been done, may also be wise to get ready to do them sooner rather than later anyhow(common issue with some klms on the clock).
    They're not hard to do, even for those of us with just the basic tool handling abilities.
    Arthur.
    '03 D2 Td5 Auto
    '03 D2a Td5 Auto
    Dec 2022
    Thanks for crank angle sensor suggestion.
    Quote Originally Posted by Tins View Post
    MDA Kinc writes: Thank you for the crank angle sensor suggestion. I will get it scanned and report.
    Dec 2022
    defender td5 130 engine cuts out
    Thanks for the tip about the crank angle sensor. The one that's in there is a new genuine one put in last July because of starting problems, which it seems to have cured. Now it starts OK but stops after 15 minutes. It feels like it is running out of fuel. Could the problem be fuel or electrical?
    Dec 2022
    defender 130 td5 engine cuts out: reply to Dazzatd5
    Many thanks Dazza TD5 for those specific suggestions. I will start with the injector harness and the red plug under the seat, as I have recently replaced the crank angle sensor.
    MDAKinc
    Sep 2010
    The Hills.
    152.79 MB
    That's why we're here. Tips are often wrong, as remote diagnosis can be like that, but sometimes they can help.
    Either. I'd look into what Dazza said about the injector harness and the red plug on the ECU, common fault, and what Arthur posted about injector seals. Ask if someone near you has a Nanocom, Disco or Deefer, it doesn't matter as long as it's unlocked for the TD5.
    ​JayTee
    Nullus Anxietus
    OKApotamus #74
    Dec 2022
    Defender 130 td5 engine cuts out, thanks to AK83
    Thanks for your brilliant and detailed help, AK83.
    I haven't got a Nanocom, but I see there is one on line for $271 plus postage from the UK. It's called iCar Soft LR V2.0. Would that be worth getting?
    As to injector seals, Bruce Davis of Windsor did them for me back in July when I had starting problems. That is when the crank angle sensor was replaced. Is it likely they would need doing again so soon? (By the way, thanks for the tip on doing them myself. I'm gennnerally a DIY man, but didn't realise I could have done this myself.)
    I'll try the bleed routine.
    MDAKinc
