Results 1 to 4 of 4
Thread: Powering a PCI-E video card
    St Helena,Melbourne
    4.28 MB
    Building up a spare i5 pc for my daughter to use and got an Asus GTX 660 card to use instead of the onboard chip, card has 2 x 6 pin power connectors but i only have 1 x 6 pin cable from the PSU.
    Looking online i can see double molex to 6 pin and sata to 6 pin, i only have 1 x molex spare so lloks like the sata to 6 pin might be the go.
    Anyone used one of these, i'm not about to replace the PSU.
    I get a message at startup to connect a power cable so one connected doesn't work.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Apr 2002
    Bellara 4507
    32.43 MB
    The double adapter is okay if the rail they are on can handle the power draw
    I try and use two separate adapters if possible
    2007 Discovery 3 SE7 TDV6 2.7
    2012 SZ Territory TX 2.7 TDCi
    St Helena,Melbourne
    4.28 MB
    Quote Originally Posted by incisor View Post
    I have one 6 pin plug I can use and will buy a sata to 6 pin lead which seems to be the easiest solution.
    Both on separate leads so should be ok.
    1974 VW Kombi bus
    St Helena,Melbourne
    4.28 MB
    Got the adapter cable today, thanks Amazon, and the daughters gaming pc is working great. i5 with 16gig ram and the 2gig video card , all up about $90 total cost.
    1974 VW Kombi bus
