Results 1 to 8 of 8
Thread: Radius arm interchangeability
    Aug 2008
    latrobe valley victoria
    I’m getting set to do my front bushes….daily driver no second car.
    Now down to tin tacks..I’ve managed the back ,however I have multiple sets of r arms sittting in the shed….are d1 arms the same as defender arms? I know I’ve likly got both d1 and rrc[imperial I’d guess…ie 80’s era ]…
    Dose anyone know if there[d1] the same arm as a 2002 defender?
    Also on topic I’ve seen SuperPro radius arm 2 part bushes and one peice ones listed for that era.
    Any thoughts or advice
    I have no access to a press if the curent ones are out
    Cheers and happy Xmas
    2002 defender 110 , 1955 86 inch
    St Helena,Melbourne
    1.13 MB
    Some time in the late 80' s there was a change in bush size it can't remember if it was diameter or width (width I think) but believe the arms are the same.
    Someone should be able to confirm that.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Aug 2008
    Thanks….
    Cheers….I was under the same impression…I think the latter bushes are wider
    Hopefully someone has a measurement
    350RRC's Avatar
    350RRC is offline ForumSage Silver Subscriber
    Hi,
    The difference is in width. Can't remember if they got wider or narrower........... I'm thinking narrower............ more articulation.
    Also .......... I've used SuperPro for a long time now and actually have a tool that was machined in 5 mins to press the one piece bushes in (using a bench vice.......... easy as), 20 years ago, in 74 RRC radius arms.
    Pretty sure the new ones I have in a packet are 2 piece, but they're different arms, front diff is braced County, MD everything, County CV's, just got to find time to slot the swivels and get rid of the stoopid caster correction bushes that came with the arms.
    Not much help, but I think the width change was done with the flanges on the diff and all the radius arms are the same.
    cheers, DL
    Aug 2008
    Quote Originally Posted by 350RRC View Post
    Hi,
    cheers, DL
    Yea some help…..I’ve thought I’ve seen both SuperPro one and two peice radius arm bushes…..so
    Two peice wouldent be an issue.
    I did the bigger ones on the back with a similar thing…….a tin ring and jubilee clips [think piston ring compressor]
    350RRC's Avatar
    Quote Originally Posted by mfc View Post
    I wuz wrong.
    The front radius arm to diff bushes got wider as the years went by. The ones I have in a packet are one piece.............I must have been thinking back to the Pedders ones that were on my POS when I bought it.
    The kit just for the arms to diff bushes I'm using is SPF 0126K............. crush tube length is 48mm. No diameter specified, but they measure 50mm with the verniers
    Suits Def 83 - 90 (KA) and RRC 69 - 86.
    Kit 01803K suits Def 1990 - 2007 on. (LA onwards), RRC 87 - 95, Disco 89 -95.
    Length 53mm, Dia 50mm.
    Dunno if the Def radius arms got thicker or not, but most parts places list different radius arm part numbers for KA vehicles compared with LA onwards.
    RRC and Disco radius arm part numbers are different again.
    cheers, DL
    Aug 2008
    Yea I thought thicker and metric nut………99.5% certain that d1 and defender are the same…..kinda thining lane rrc is the thicker arms to
    Although looking at SuperPro they list both split and bob in style.
    Split would be handy to fit
    Geelong, VIC
    Early county were narrower, but from D1 onwards the D1/Defender are the same.
    At a push you can fit the narrow early arms to the wider bracket D1 axle housing by making up some 5mm thick spacers. Did this recently on my 85 County as I’d rebuilt a D1 housing to install, then found the D1 arms I was planning to fit had been badly gouged with an oxy torch previously so I had to use the original narrow ones.
    Steve
    1985 County - Isuzu 4bd1 with HX30W turbo, LT95, 255/85-16 KM2's
    1988 120 with rust and potential
    1999 300tdi 130 single cab - "stock as bro"
    2003 D2a Td5 - the boss's daily drive
