Results 1 to 10 of 21
Thread: Stopping phone apps using mobile data
    NE Victoria
    32.83 MB
    Hi All, and a happy new year.
    Is there any way you can stop an app from accessing mobile data?
    Instagram and Spotify in particular, but I have others I would like disabled as well.
    I have background data off, but they are still using more data than I think they should, and more data then I have.
    Phone is a Samsung Note 9, Android 10.
    Thanks in advance.
    Tony
    I know how to do it on an iPhone but not Android.
    Go into settings, select Apps and Notifications - under recent apps listed at the top you will see See All $% apps - select that - then select the app you are are interested in from the list - you will see near the top Open, Uninstall, Force Stop - select Force Stop and this will stop the app but not remove it. If you open it you will have to go through the process again.
    NE Victoria
    32.83 MB
    Quote Originally Posted by 101RRS View Post
    Thank for that, but there must be a better way.
    For the last month I've just been turning off mobile data, unless I need it on, with no change in Instagram, Spotify sometimes gets a bit cranky as does Google Maps.
    Tony
    It literally takes 2 secs to do. About as long as it does to turn mobile data off.
    NE Victoria
    32.83 MB
    But it doesn't solve the problem if I'm listening to music on Spotify in the car.
    I'm using a saved play list, Spotify needs to be running and it's using mobile data.
    Tony
    Mar 2015
    Horsham Victoria
    I’m confused to what advice your after. Your post asked about turning off apps, which has been described, now you say it doesn’t fix the problem, you wanted to turn apps off specially Spotify now you won’t Spotify running?
    NE Victoria
    32.83 MB
    Quote Originally Posted by RobMichelle View Post
    No, I want to stop some/many apps from accessing mobile data, not stop them from running.
    Tony
    Avoca Beach
    I have a solution for easy isolation of apps from mobile data.
    get an Iphone. Each app on an iphone has the option of mobile data.
    You just go the to the apps in settings and move the mobile data button to the left.
    Sorry but I couldn't resist. I tried but the devil got me.
    Regards PhilipA
    May 2014
    Point Cook, VIC
    Quote Originally Posted by TonyC View Post
    Tony
    Other than blocking background data Android doesn’t allow you to block individual apps if they are running in the foreground. (Without turning all data off across all apps).
    So you will need to run another app to act as a firewall to block data usage on an app by app basis - like NetGuard.
    Being Android you will need to do your own research if you want to use another app to control your device.
