Results 1 to 9 of 9
Thread: 20w 60
    Aug 2018
    20w 60
    Hi all, can I put 20w 60 motor oil in my 4.0 disco 3? I tow a caravan and when I’m in heavy traffic the engine oil light comes on and off when idling. I’ve check the oil level and it’s full and the oil hasn’t even done 5000km yet.
    Thanks.
    Mar 2018
    Perth (near Malaga)
    What’s in it now? 60 is pretty heavy.
    Back down the hill.
    You're better fixing the primary issue, rather than the symptoms.
    It could be the sender or the pump.
    I wouldn't.
    Modern engines usually use a much lighter grade, e.g., 5W40 full synthetic, not just for fuel economy reasons. Dunno about the D3, though.
    St Helena,Melbourne
    4.28 MB
    Definitely not 20w60, you could try 5w40, I think the factory spec is 5w30?
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Jan 2012
    5w 30 is the LR spec.
    LR Time and a few other Ewetubers reco 5w40.
    I’m getting pop corn ready…
    Apr 2012
    Whyalla, SA
    Quote Originally Posted by vince64 View Post
    Thanks.
    One word - Bang!
    Look to replace the oil pump and solve the issue correctly.
    St Helena,Melbourne
    4.28 MB
    Quote Originally Posted by SimmAus View Post
    For the petrol motor as well ? , diesel is 5W30 i assume the petrol V6 is the same.
    1974 VW Kombi bus
    NSW far north coast
    I'd be checking the at idle oil pressure, it could be the sender.
