Thread: Classic door locks
    Jul 2021
    Classic door locks
    My 82 RRC has a different ignition key to the doors.
    I found on line a matching ignition lock with door locks so I clicked “buy it now”.
    On further investigation today I discovered that the “new” door locks have the operating lever in a different orientation to my original locks.
    Original lock on the left operates the vertical link rod to the door latch.
    The “new” right hand one has the operating lever vertical. Is this from an early 4 Door that still had the seperate door lock
    Phil
    Quote Originally Posted by Phil 850 View Post
    Phil
    Hi Phil,
    I was doing routine crisis maintenance on my D/S door lock last week and was looking for a schematic of the actual lock when I came across a vid that included the comment that the barrels are easy to reconfigure for any RRC key.
    Will have a look for it tomorrow............... was a pommy resto site and the guy was showing how to get the barrels out of the door.
    Maybe goog 'RRC door lock removal'.
    cheers, David L
    Jul 2021
    Hi David
    The reason I bought matching ignition and door locks is because my ignition key is the opposite hand of the door key.
    To explain that further, in the previously posted photo, look at the shape of the hole that the key fits through.
    This is the new door lock that I bought and the key “section” (cross section of the key) matches my original ignition key.
    Now look at the left hand image and the key “section” is the opposite way around.
    Consequently, changing the leaves (or whatever they are called) will still not fix the issue.
    Phil
    Sep 2010
    The Hills.
    152.79 MB
    Phil
    They're called wafers, and no, changing them won't help. The pic doesn't show a side view. Is it possible to change the lever to the other barrel? Often it's just a C clip holding that on, but I can't quite see it.
    ​JayTee
    Nullus Anxietus
    Cancer is gender blind.
    2000 D2 TD5 Auto: Tins
    1994 D1 300TDi Manual: Dave
    1980 SIII Petrol Tray: Doris
    OKApotamus #74
    Nanocom, D2 TD5 only.
    Jul 2021
    Hi Jay Tee,
    I had a more detailed look at my “new” locks and they are marked LH and RH and the levers cannot be changed from barrel to barrel unfortunately.
    Original 82 RRC on the left, RH lock in the centre and LH lock on the right.
    All three locks have the same locating lugs in the same orientation and with the key vertical.
    Are the centre and right ones from the early 4 door with the separate locks?
    Phil
