Results 1 to 10 of 19
Thread: Panel efficiency experiment
    Sep 2010
    The Hills.
    152.79 MB
    I found this to be interesting. I'm not sure how helpful it is in a mobile setup.... yet.
    ​JayTee
    Nullus Anxietus
    Cancer is gender blind.
    2000 D2 TD5 Auto: Tins
    1994 D1 300TDi Manual: Dave
    1980 SIII Petrol Tray: Doris
    OKApotamus #74
    Nanocom, D2 TD5 only.
    Queensland
    Thanks JayTee, that was a truely interesting video.
    Some 15 odd years ago, a company I use to deal with, imported some special solar panels from Turkey.
    These panels had tubing fixed to the back of the solar panels ( like the info in that video ) but while the tubing was intended to cool the solar panel but the water was intended to be used in a domestic hot water system.
    I have demonstrated, on numerous occasions, how just pouring cold water over a hot solar panel increases to output substantially, to most observers disbelief.
    I have never considered or heard of using air flow to cool a solar panel.
    If I ever get some spare time, I must try out his experiment.
    Apr 2012
    Whyalla, SA
    Simple enough tech, weight in mobile situations would be horrendous!
    I'd suggest for a long term static install (house etc) may pay off over time
    Thanks for posting
    Sep 2010
    The Hills.
    152.79 MB
    Agreed, which is why I used the qualifier "yet". I imagine early commercial use of this idea would have a "horrendous" price tag as well.
    ​JayTee
    Nullus Anxietus
    OKApotamus #74
    Heathcote Junction
    Stands to reason
    We are building some huge Data Centres & while i know they are not the same they must be kept cool to operate efficiently.
    Chuck
    MY 24 Grenadier Trialmaster
    MY 03 D2a
    Ex D1, D2, D2a, D3, D4, Prado, D4, D5, MY 23 Defender
    73 series 3 109 Truck Cab Tray Body, 79 Series, 76 Series
    Sep 2010
    The Hills.
    152.79 MB
    Trouble with using airflow to cool panels in a mobile application is that, while there can be plenty of it, it happens precisely when you don't need it!
    ​JayTee
    Nullus Anxietus
    OKApotamus #74
    Sep 2010
    The Hills.
    152.79 MB
    Quote Originally Posted by chuck View Post
    Stands to reason
    I imagine heat dissipation is of major concern when designing those. You could probably heat a small city off googles servers alone.
    ​JayTee
    Nullus Anxietus
    OKApotamus #74
    Yes, I tested this on my home solar panels. The output definitely rose.
    Sep 2010
    The Hills.
    152.79 MB
    That effect is not noticeable in Melbourne when it rains... Oh, wait...
    ​JayTee
    Nullus Anxietus
    OKApotamus #74
    Queensland
    I have always been of the belief that in a mobile situation, ( where possible ) simply increasing the solar panel size gets around the messing around of lots of work for a small gain!
    But for a static setup, this is interesting!
