 Fossicker
						Fossicker
						Hi in my 2010 RRSport, fault is displaying on the centre screen of "Stability Control Not Available Drive with Care" and "Emergency Brake Assist not Available"
Looks like the Stability Control is disabled, even if restarting engine etc, the icon displays on screen as well. But didn't select the Stability Control button, and wont reactive when pushing it.
I have a iCarsoft CRPRo scanner and not able to find any faults.
How do we reset it back to normal driving mode?
thankyou
 Fossicker
						Fossicker
						Sounds like an ABS or wheel height sensor is out of range. It will almost certainly be logging a fault, so getting a dealer or Indy to check the fault codes would be a sensible place to start.
2013 D4 expedition equipped
1966 Army workshop trailer
I can highly recommend getting a GAP IID tools diag. The messages that come up on the screen are very generic and not much help compared with the actual error code / reason to show the message.
 Fossicker
						Fossicker
						That is just parked, its normally straight
