 Fossicker
						Supporter
						Fossicker
						SupporterHi All
Strange one. Car is in TTM set with IID tool. Went into the mode fine but will not go back to normal tolerance. The tool says operation successful but no change. Restarting. Disconnect battery seems to make no difference.
edit: google answer worked:
Re-enable
Set Normal Tolerance
Build Mode
Now the camera isnt working and I have a spare plug near the battery that clearly should go somewhere... Too dark!
I had this happen to me except i didnt disconnect the battery.. i had to re enable TTM and try and get it back to normal mode.. first time didnt work even tho it said it was in normal mode i still had the red suspension fault which i couldnt clear ... drove about 50 mtrs and re enabled TTM and then tried normal mode and it worked..
Cant comment on the spare plug or the camera issue but it sounds like its related especially if you removed the battery leads in the dark.
Cheers Bulletman
 Fossicker
						Supporter
						Fossicker
						SupporterYes. I think it is the plug for the transit relay. Thanks.
Camera is all good, just needed some time.
I had to perform the recovery steps twice to get to normal.tolerance last night but today it was behaving fine when I had the wheel alignment done.
