Results 1 to 9 of 9
Thread: Bolt Cutters…..
    Apr 2019
    Bolt Cutters…..
    Why are they called bolt cutter??
    I’ve never needed to cut a ‘bolt’ with bolt cutters….
    The other day work asked me to bring up a set of bolt cutters as they’d lost the key to a lock….
    I said so you need me to bring the lock cutter….there was a pause.
    I said I’ve got this as I have the master key, to which they said that there is no way I’d have a master key that would cover this random lock…..
    I turn up with grinder and cutting disc.
    Soooooooo, still confused as the why bolt cutter are called ‘bolt’ cuttters
    Aug 2008
    Perth, WA
    37.36 MB
    I was always under the impression that bolt cutters got their name from cutting the bolts off shipping containers. However, I've seen photo's of bolt cutters being used in shipyards in the late 1800's (way before shipping containers were invented) so don't know how true that is, or what they were called before then.
    Life is just a series of obstacles preventing you from taking a nap.
    99.87 MB
    I call them Skeleton keys also.
    Slunnie
    Jan 2010
    Crescent H.K. Porter | Crescent Tools
    "In 1880, Henry K. Porter, a partner in a machine shop in Boston, patented an adjustable “bolt cutter.” It was originally designed for blacksmiths to snip off the excess length of bolts after the nut had been tightened."
    For small bolts around M4 M5 size I like the ones found on a lot of wire stripper/crimper combo tools, as they have a thread that you can screw the bolt in, so leave a nice clean cut, otherwise if cutting bolts with hacksaw or grinder I put a nut on the bolt first, then cut it and then unwind the nut which usually cleans up the threads enough to use.
    2005 D3 TDV6 Present
    1999 D2 TD5 Gone
    Apr 2019
    Quote Originally Posted by cripesamighty View Post
    Was wondering what the pin type lock on a container is called
    Sep 2010
    The Hills.
    152.79 MB
    Quote Originally Posted by W&KO View Post
    We always called the solid ones "bolt seals", or simply seals. This is based on them being customs seals, individually numbered and recorded. which is why they can only be cut, not unlocked. There are local seals as well, numbered for inventory security, but they usually only require snips.
    ​JayTee
    Nullus Anxietus
    Cancer is gender blind.
    2000 D2 TD5 Auto: Tins
    1994 D1 300TDi Manual: Dave
    1980 SIII Petrol Tray: Doris
    OKApotamus #74
    Nanocom, D2 TD5 only.
    Apr 2012
    Whyalla, SA
    Even more fun now with 18v Bolt cutters Bolt Cutters…..
    Sep 2010
    The Hills.
    152.79 MB
    Yes. Cordless cutters were very thin on the ground when I was dealing with boxes.
    ​JayTee
    Nullus Anxietus
    OKApotamus #74
    Jan 2010
    I should've known how bolt cutters got their name, as some of my ancestors were wheel wrights and coach builders. I am glad to know now though.
    1999 D2 TD5 Gone
