Results 1 to 10 of 21
Thread: Puma 2.4 clutch replacement parts
    Geelong, VIC
    Spent a few hours of quality time with the County today - taking our D2 on a trailer to my daughter and family after their Puma crapped its clutch while in Moama for the weekend.
    The Puma is now at my place, waiting for their benevolent mechanic to do a clutch change.
    Its mostly the daughter's daily drive, but they do use it to tow their 16' caravan when they go away for weekends.
    Whats the current recommendation for a replacement clutch and slave cylinder etc?
    I see Ashcrofts do a HD "Clutchfix" unit, and looks like there's an AP(OEM??) one available easily locally?
    Steve
    1985 County - Isuzu 4bd1 with HX30W turbo, LT95, 255/85-16 KM2's
    1988 120 with rust and potential
    1999 300tdi 130 single cab - "stock as bro"
    2003 D2a Td5 - the boss's daily drive
    Jun 2008
    Drouin East, Vic
    Not so much a recommendation, just what I did- I got a LOF clutch kit from the UK. Also installed their one-piece shaft between the boxes. Too soon to comment on any of it.
    Pete
    Geelong, VIC
    Thanks Pete.
    I've just ordered a LOF "PowerSpec" kit along with a LOF master cyl from LRParts.net.
    The kit includes the slave, adapter and control valve and spigot bearing (which hopefully I won't need) along with a new rear crank seal.
    AUD$890 delivered.
    Supposedly a H/D clutch suited to towing etc but with the same pedal force as original.
    Will see, but at least if the aforementioned daughter ends up with left thigh like a weightlifter she can't say I didn't try to do the right thing
    Steve
    Brisbane,some of the time.
    I would do a search on here,Dazza has somereally good info on what clutches he uses.
    Jun 2008
    Drouin East, Vic
    One thing I can tell you Steve from my rebuild, bleeding the clutch was an absolute pig. I ended up having to reverse bleed it, jury-rigged with some IV fittings and a 50ml syringe.
    Hobart
    Quote Originally Posted by steveG View Post
    Thanks Pete.
    AUD$890 delivered.
    Steve
    Hi Steve,
    How did you manage that price? I went through process and was quoted £380 for freight alone.
    Cheers, Peter
    Geelong, VIC
    I reckon something has gone wrong with the shipping calc when you did it.
    Here’s my order confirmation from them.
    Steve
    Hobart
    My mistake as I wasn’t comparing apples with apples. The kit I was looking at included the flywheel.
    Cheers, Peter.
    Geelong, VIC
    Yeah - that would bump the freight up!
    Steve
    Jan 2014
    Perth Western Australia
    I've used most brands of clutches and wont use anything but the ClutchFix brand, yes I do import them direct from ClutchFix (for my own workshop use).
    If the OP does a search, or maybe look at my previous posts? I have posted all the part numbers for the hydraulics and everything you need to do the job, half do it and you will be pulling the gearbox out again to do whatever failed.
    Daz
