Not required.. 3.0L engine runs its own EGT so the ECU has you covered.
I believe you can monitor using GAP tool in instrument mode
Hi all,
Re Exhaust Gas Temperature gauge please
- Who runs one?
- Worth worrying about?
- Can the Gap diagnostics be used for this?
- If not, is there a bluetooth or app based version?
TIA
2011 SDV6 3.0L + Torus Kakadu, Winchbar, UHF, roof racks, 1 wife, 4 dogs, not enough fishing rods, and Wallabies supporter.
It was a personal import, and it did have DPF, yes. There were a number of changes to the MY08 to accommodate EU4 and DPF (such as setting faults on EGR flow). I wonder if the EGT connector is in the MY08-> harness.
It'd be interesting to see if the GAP list on other cars has the "catalyst temperature sensors" elements listed in the "complete" list. The one I use is the "Pre-catalyst Exhaust Gas Temperature".
