 Originally Posted by
PerthDisco
				Blocks don’t fail like that. I’d say it’s a compressor fault that caused the system to drop.
 Not likely to cause a drop in the suspension - these are controlled by the various valves blocks.  I have driven my car without a compressor fitted and while it settled a little when the levelled it did not drop.
I suspect there is crud in the valve block that prevents the valve closing when it should - this could indicate a compressor issue as the crud can come from the desiccant.
If me I would clean out the valve block and see if that fixes the issue - if not go looking further.
