Results 1 to 8 of 8
Thread: Talk me out of buying this County
    Feb 2023
    Queensland
    Hi All
    New member here. I’m looking at buying an unregistered 86 Isuzu county with 5 speed gear box. Electronics don’t work, doors full of rust, chassis recently painted (red flag), rust in bulkhead (in fact rust everywhere you’d expect), rear cross member replaced, drives - engine sounds good and gets through the gears without anything too scary.
    My goal would be to get this car to a point where I can drive it to and from work locally. Ideally I’d like to be able to do some trips in it but am I just completely kidding myself?
    I’ve spoken to a local LR specialist who advised upwards of $2k per door for rust fix, up to $10k for bulkhead… very quickly does a cheap buy become very expensive.
    I realise everything can be fixed for a price but am I completely kidding myself on this?
    Jun 2013
    Universe A
    Quote Originally Posted by cjgraham92 View Post
    Hi All
    You could certainly find better ones, but it all comes down to $$ I guess.
    What ball park figure are they asking for it?
    If they are genuine about the cost of repair, I should really quit my day job and start fixing them for a crust
    Feb 2023
    Queensland
    Quote Originally Posted by shack View Post
    Hi Shack
    thanks for the reply - c. $11k
    Geelong, VIC
    Are you planning to work on it yourself at all or will it be a case of handing over the cash and a big bucket of money to get everything done?
    Purchase price aside for a minute, if you were taking it on as a resto project yourself the doors and bulkhead don’t look too bad.
    Doors aren’t a big deal, but there’s a fair chunk of time in a bulkhead removal/refit if that was required.
    Chassis you’d definitely want to have a close look at - if it’s rotten then you’re looking at a ground up rebuild so it’s really just a collection of parts rolling on county axles.
    Nothing hard about them, just a big boy’s mechanic set and if you’ve got the time/space and capability to plug away at it it’s definitely doable.
    But If you’re having to pay somebody else to do all the work I think you’ll be north of $25k before you blink.
    Steve
    1985 County - Isuzu 4bd1 with HX30W turbo, LT95, 255/85-16 KM2's
    1988 120 with rust and potential
    1999 300tdi 130 single cab - "stock as bro"
    2003 D2a Td5 - the boss's daily drive
    Sep 2010
    The Hills.
    152.79 MB
    Hi All
    $2K per door seems a little steep.... I mean, you can get these from Turkey Land Rover Defender Brand New Front Doors Full Kit - For Sale Land Rover Defender, but surely a hunt for SH ones is possible.
    The same mob do bulkheads. After that it's just work. Land Rover Defender Bulkhead galvanised - For Sale Land Rover Defender
    I'm not recommending those bits from Turkey, as I've never seen them, but they are an example of what's available.
    ​JayTee
    Nullus Anxietus
    Cancer is gender blind.
    2000 D2 TD5 Auto: Tins
    1994 D1 300TDi Manual: Dave
    1980 SIII Petrol Tray: Doris
    OKApotamus #74
    Nanocom, D2 TD5 only.
    Feb 2023
    Queensland
    Quote Originally Posted by steveG View Post
    Steve
    Cheers Steve - definitely keen to do as much myself as I can. My big issue is keeping my wife on board with this plan... More than happy to plug away but i'm keen to get it on the road ASAP (if wife doesn't veto)
    Apr 2019
    Medowie
    I think the quote probably falls into the category “I don’t want to do the job so I’ll try to scare him away”. SP4x4 make nice gal doors for a few hundred dollars each. You can also get pre-fab bits to weld into the bulkhead in the common rust spots. Be careful to check the chassis though, as while pre-fab bits are also available to weld on for repair, some may involve challenging welding positions or stripping of the vehicle to do properly. I get all my body/chassis repair bits from the UK direct, it’s usually quite a bit cheaper than sourcing locally. It all really depends on how much effort you’re willing to sign on for, time tends to cost more than parts for this sort of work, but I personally find it therapeutic and rewarding…
    Sep 2010
    The Hills.
    152.79 MB
    With all the other advice here, there are also a couple of yt channels to make it all seem doable. Mike at Britrest is definitely one to check out, but if you really need 'shaming' into doing it then Land Rover Sophie is there as well I definitely feel lazy after watching her.
    Defender footwell, door pillar, and upper bulkhead repair. Pt 1 removal of parts - YouTube
    The New Project - Land Rover Series III - YouTube
    ​JayTee
    Nullus Anxietus
    OKApotamus #74
