Results 1 to 9 of 9
Thread: Need Diagnostic Tool for Disco 4 To Check Oil Level
    Feb 2023
    Hi there, my Disco 4 is generating fault code P060B. LR dealer investigated and advised issue is with Oil Level Sensor. Quoted $5K+ to replace. Hoping to get my hands on a diagnostic tool to check oil level as a temporary solution until we can afford this rather expensive dip stick to be replaced 🤪 Hoping someone can tell me what tool to buy, what I should expect to pay, and where to get it? Thanks Dexter
    Apr 2012
    Whyalla, SA
    Quote Originally Posted by Dexter View Post
    The tool reads from the exact same sensor - so if your sensor is faulty - you wont get a reading
    St Helena,Melbourne
    1.13 MB
    Put a rod of some sort down the suction tube.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Nov 2015
    Black Rock
    I've wondered what I would do if I had this problem (oil level sensor not working) and I suspect I would just live with it. After all, if you replace the oil and filter every 6 months or 10k kms then all you have to do is keep an eye out for oil leaks. After all, oil will either leak out or be sent down the exhaust. In either event it will be obvious and the engine will need serious work so you can sort out the sensor then.
    Say what you like about the engine and transmission, but they are very clean units, so leaks can be picked up very early.
    2013 D4 expedition equipped
    1966 Army workshop trailer
    Jan 2012
    Quote Originally Posted by DieselLSE View Post
    I've wondered what I would do if I had this problem (oil level sensor not working) and I suspect I would just live with it..
    Agree…and $5k repair would pay for the next few years of oil changes.(irrespective of what oil you decide to run ;-). )
    josh.huber Guest
    Drain oil and filter, add 5.7l of oil..
    Or get another decent quote
    Melbourne, AU
    _________________________
    1996 D1 V8 - gone
    2002 D2 Td5 ES- gone but still running elsewhere
    2013 D4 SDV6 HSE - gone
    2023 Defender 110SE D300
    Jun 2008
    The new Gold Coast, after ocean rises,Queensland
    I have a thing called EDS bought cheap from Kings
    It will read out everything that is on your ecu, your 4 favourites fulltime and simple select anything like oil level....it is read only.
    Sep 2010
    The Hills.
    152.79 MB
    Quote Originally Posted by jwb View Post
    OMG!! Vera is hilarious. My wife knew to make herself scarce in situations like these.
    You can see the $5K quote a little more clearly though after watching this.
    ​JayTee
    Nullus Anxietus
    Cancer is gender blind.
    2000 D2 TD5 Auto: Tins
    1994 D1 300TDi Manual: Dave
    1980 SIII Petrol Tray: Doris
    OKApotamus #74
    Nanocom, D2 TD5 only.
