Thread: Little surprise
    Dec 2010
    Kiewa Valley, VIC
    Little surprise
    Well, just as I was thinking that the internals were ok, number 1 had a little surprise in store.
    Question: how bad is too bad?, and this is out of an 86 in but the piston is stamped 1949… I’m guessing that must have been a busy year for piston production. I can’t see and reference to size, so I’m guessing this is a standard sized piston. Would that be correct?
    Mustlust
    1950 Series 1 80in lights behind grill
    1950 Series 1 80in rolling chassis looking for a body
    1956 Series 1 86in
    1956 Series 1 107
    1957 Series 1 88in
    1967 Mustang coupe 347 stroker
    2011 Discovery 4 3.0
    2009 110 utility 2.4tdci
    Jul 2009
    S.E.Qld
    Measure the piston! 1947 is probably the piston manufacturer's part number.
    .W.
    Sep 2012
    Westlake ,brisbane
    Quote Originally Posted by Mustlust View Post
    That piston is beyond it. As BSF said probably P/Number. You will need to measure the piston to find out the size.
    I was up at our workshop the other day getting a couple of parts for someone & came across my old pistons out of my early 1950 was going to bring them home but decided not to other wise I would have checked what was on them.
    Dec 2010
    Kiewa Valley, VIC
    Any idea where I can source a replacement piston? Measurements suggest they are all standard size.
    Mustlust
    1956 Series 1 86in
    1956 Series 1 107
    1957 Series 1 88in
    Sep 2012
    Westlake ,brisbane
    I bought pistons from JP Pistons for my 1949 Rover P3 75. Same style of piston only different size, I never had a problem with them while I owned the vehicle & they had them on the shelf. Think they are in SA you could give them a try.
