Results 1 to 10 of 17
Thread: Transmission or XYZ switch?
    Hobart
    I’m considering the purchase of a D2 that is having some issues selecting reverse. It will select when shifting from P but not from D. Has anyone experienced similar? Does it sound like a switch fault or transmission? Vehicle has only travelled 140k kms and looks like very little off road, however, boot around transfer lever is well used. Doesn’t look like it’s been a tow tug either. Bit of a mystery.
    Peter
    2008 Range Rover Sport TDV8
    1973 Range Rover Classic "Suffix B"
    Sep 2010
    The Hills.
    152.79 MB
    Quote Originally Posted by discopete View Post
    Peter
    What does it show in the odo screen? What light comes on in the selector? If those are normal then it's probably not the switch. But the XYZ doesn't actually select the gear, the cable does that. The switch tells the computer what gear has been selected. I know that is an oversimplification, I'm only trying to show that there is a third place to check and that is the cable. Even the nut holding the selector arm on to the trans could have come loose. They seem pretty sensitive to adjustment.
    As for the boot, do you mean the gaiter in the console or the rubber boot beneath it? Mine has done 350K and there is little wear to that gaiter, and I have certainly used the transfer lever a lot.
    140K is just a baby, so unless there's been abuse or poor maintenance I'd expect the trans to do more than that.
    EDIT: On the occasions my trans has failed reverse was the one gear that DID work. FWIW.
    ​JayTee
    Nullus Anxietus
    Cancer is gender blind.
    2000 D2 TD5 Auto: Tins
    1994 D1 300TDi Manual: Dave
    1980 SIII Petrol Tray: Doris
    OKApotamus #74
    Nanocom, D2 TD5 only.
    Hobart
    Quote Originally Posted by Tins View Post
    Yes, my understanding was limited to the two possibilities and hence my turning to the more knowledgeable. I’ll have a better look this coming weekend if it hasn’t sold in the meantime, and also pay more attention to dash display. It’s the console gaiter I was referring to. Both handbrake and transfer lever gaiters are similarly worn. They look shocking! Seems strange for a low km vehicle.
    And reverse seems to work fine once selected, it’s just the oddity of not selecting after being in D.
    Peter
    Sep 2010
    The Hills.
    152.79 MB
    Far more knowledgeable people than me on here, but I do have some experience of trans issues in a D2
    That could simply be down to aggressive cleaning products, or that things were loosely stored there, or they were replaced with cheap aftermarket ones.
    The oddity you speak of could be the cable mechanism... coming to reverse from the opposite direction, so to speak, could see it not pushing/pulling the selector quite far enough. The XYZ moves with the selector arm, so the display could also indicate a misadjustment.
    All this is guesswork of course.
    ​JayTee
    Nullus Anxietus
    OKApotamus #74
    Sep 2018
    Travancore
    The leather is poor quality as to finish, both my D2 and D2a have the issue you talking about with the gaiter looking 'shredded' but this is only the finish and not the leather itself. The D2a has not been off road or towed but the gaiter is awful.
    As most will attest to the XYZ switch is problematic and as such it is important to check the display to match the console.
    2004 Discovery 2a TD5 Auto Aspen Green AKA Robin
    2000 Discovery 2 TD5 Auto Alverston Red AKA Edward
    1997 Discovery 1 TDi Manual White - Gone but not forgotten
    1994 Discovery 1 V8 Auto - Gone once it consumed half the worlds resource of oil
    Jan 2011
    Burpengary, QLD
    Just a a warning, my xyz switch wasn't working properly but the dash display was fine, make sure the reverse lights are working when reverse is selected, if they are not, that's likely the switch.
    P38 Range Rover , the best car in the world, when it's working
    Heathcote Junction
    I recently had my XVZ switch rebuilt.
    Prior to the rebuild there was a lot of slop in the shift lever & if it missed a shift the M & S lights would come on.
    You have some good Landrover Indies down your way why not see if they can do a prepurchase inspection?
    Chuck
    MY 24 Grenadier Trialmaster
    MY 03 D2a
    Ex D1, D2, D2a, D3, D4, Prado, D4, D5, MY 23 Defender
    73 series 3 109 Truck Cab Tray Body, 79 Series, 76 Series
    Sep 2010
    The Hills.
    152.79 MB
    Quote Originally Posted by chuck View Post
    I would suggest that you had two things repaired simultaneously. The XYZ switch on its own can't be responsible for slop in the shift, as it merely piggybacks on the selector shaft into the trans. A good shop would have addressed wear or slop in the mechanism while they were at it.
    ​JayTee
    Nullus Anxietus
    OKApotamus #74
    Hobart
    One of the best. It’s a matter of getting in with JC. I’m working on a pricing for worst case scenario at the moment. Keen to get a better understanding of transmission operation and other’s experience in the meantime.
    Avoca Beach
    The boots on the handbrake and slow range are cheap on ebay and easily replaced.
    Its just a matter of prising out a spring base on the selector and ditto the handbrake.
    Regards PhilipA
    eg Land Rover Discovery 2 Shift Boot + Handbrake Genuine Leather Tobacco | eBay
