Results 1 to 10 of 23
Thread: No aircon 05 L319!
    Dec 2020
    Diamond Creek, Vic
    No aircon 05 L319!
    Hi, on Friday the AC failed 2hrs into a 5hr drive with a 39degree day. Before I rip into replacing parts I want to get the system tested. The local AC specialists (Diamond Creek) can't fit me in for a couple of weeks. Can anyone recommend someone who knows Disco AC systems in the Northern part of Melbourne who may be able to test/degas the system for me? Thanks
    Aug 2008
    Perth, WA
    37.36 MB
    Did it die completely or was it just blowing warm air? If it helps, mine of late has the air con running for a while and then blows warm air. I cycle through the air con on/off, auto, etc and it comes back online. I don't know if it is a portend of things to come, or I need to service something.
    Life is just a series of obstacles preventing you from taking a nap.
    Melbourne, AU
    Had that a couple of years ago.
    Aircon shop topped up refrigerant and it worked sort of for a while.
    Needed compressor replaced.
    _________________________
    1996 D1 V8 - gone
    2002 D2 Td5 ES- gone but still running elsewhere
    2013 D4 SDV6 HSE - gone
    2023 Defender 110SE D300
    Dec 2020
    Diamond Creek, Vic
    Quote Originally Posted by cripesamighty View Post
    The fan runs but there is no cooling. I've cycled through all of the controls a number of times to no avail. The fuse - 51 in the main junction box - is ok, so there is a problem in the system.
    Jun 2017
    Crows Nest Qld
    I've found Romsey British Auto very helpfull when travelling through a couple of times
    Romsey British Automotive | Offering a full range of servicing for Land Rover & Range Rover vehicles, Romsey British Automotive helps customers from all over Victoria.
    Maybe worth a call if not too far out.
    LuckyLes
    BradC is offline Super Moderator
    No one of consequence
    Supporter
    Mar 2018
    Perth (near Malaga)
    Quote Originally Posted by Airmech953 View Post
    Do you have a Gap tool? If so, have a look at the high side pressure. That'll at least tell you if there's any gas in there.
    Jan 2010
    Get it's gas topped up as a matter of urgency, as the gas helps carry the oil around, the lack of which will lead to an a/c compressor failure.
    2005 D3 TDV6 Present
    1999 D2 TD5 Gone
    Dec 2020
    Diamond Creek, Vic
    Quote Originally Posted by BradC View Post
    thanks Brad, system pressure is 875kPa, so I guess that there's gas in the system.
    Supporter
    Mar 2018
    Perth (near Malaga)
    It would appear so. 8.75 bar is ~34C. That's what you'd expect for a system not pumping on a day around that temp. Whats the ambient temp?
    What about the compressor valve % (on my D3 it's listed as "compressor current")?
    Did it die on the road or was it a "fail to start" after a rest stop?
    josh.huber Guest
    I used to drive with one wheel off the road to get the compressor to shake into action. It'll likey be it had gone to God sorry..
