my guess off the cuff...
*yes it looks like the o-ring on the intake Y piece is leaking, generally not as bad as yours so maybe the o-ring has split.
*split top turbo hose (2.7 or 3.0)
*split inlet manifold (but your engine cover looks clean)
*turbo boost solenoid hose leak (front right of engine, when standing in front of it) 2 solenoids on top of the front plastic timing cover, look for any split hoses or hoses that have gone squishy and popped off.
*more small hoses, go left towards the centre of the engine under and just left of the top coolant pipe there are more rubber hoses, again look for split or squishy ones.
*follow all the plastic hoses that run over the Y intake and at the back on the drivers side there are more small rubber hoses, again look for a split one or i think there is a plastic T piece that I have had split.
