 Fossicker
						Fossicker
						Hi, how can you adjust the Ride Height in the computer to be the actual height?
I have just replaced the compressor motor and the rear left ride height sensor, but the rear left reads about 10mm different to the right side and to the front sides. I have measured them on flat ground and they are the same height but appears that the rear left thinks it 10mm higher than what is actually.
I have "icarsoft CR Pro" reader and can view the live data. It is reading the height as goes up and down, but there is no way to adjust the rear left side, any ideas on how to adjust it in the module?
thanks
Warren
 Swaggie
						Swaggie
						Before recalibrating the sensor you might try rotating the sensor after having loosened its mounting screws, trying 1 direction then the other to see if either brings the reading closer to the others. Obviously the screws will need to be tightened after each rotation. If that doesn't make the readings close enough then you'll need a diagnostic tool capable of recalibrating or adjusting the sensors.
