Results 1 to 10 of 32
Thread: 18" alloys for a 2013 D4 TDV6 3.0
    North Avoca
    Can anyone confirm that the following specification is correct for 18" rims for a 3.0 2013 D4?
    Size 18/8
    PCD 5/120
    Offset 45 mm
    Load 950 Kg
    Bore 72.6 mm
    Thanks in advance.
    Mellow Yellow
    No matter what the problem - there's a solution. You've just got to find it.
    2013 Discovery 4 TDV6 3.0
    2015 Defender 90 - The TARDIS (Gone)
    2003 Defender 110 - The Yellow Peril (Gone but remembered fondly)
    2001 Discovery II TD5 (Gone)
    1986 County V8 (Gone)
    Apr 2012
    Whyalla, SA
    Yes, (although factory offset +53)
    What’s your end game?
    Caliper clearance is the challenge.
    North Avoca
    Thanks for that.
    I assume the +45 offset is to allow for the increased width of an 18" tyre, i.e. 265 vs 255.
    My end game after the change to 18" tyres is that both tyres and alloy rims are:-
    1. Legal.
    2. Tyres don't rub.
    3. Minimal change to tyre diameter.
    4. Tyres of a size that is readily available.
    5. Tyres with an "All Terrain" pattern.
    6. Tyres that have a proven performance in Australian desert, gravel road and fire trails.
    7. Tyres have good stake resistance.
    8. Alloy rims are from a reputable supplier, not black in colour and not a "fancy" design.
    8. Fitted to my D4 by mid-May this year at the latest, prior to a long outback 4wd trip (Yulara to Port Hedland).
    I as far as I can see 265/60R18 BFG A/T KO2's would meet the tyre requirements.
    The problem is getting suitable rims in time. In that regard, Performance Alloys in the UK will export to Australia (not cheap but not unreasonable) but I cannot afford to order the wrong spec rims. That would be a disaster.
    As to caliper issues, I have yet to take measurements as I'm away from home at the moment. But when I'm back next week ......
    Mellow Yellow
    St Helena,Melbourne
    4.28 MB
    Quote Originally Posted by Mellow Yellow View Post
    Thanks for that.
    1. Legal.
    2. Tyres don't rub.
    Cant go past the Tuffant rims and 265/60/18 tyre size, i'd go Falken Wildpeak before BFG.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Dec 2009
    Baldivis WA
    Thanks for that.
    1. Legal.
    2. Tyres don't rub.
    Have you looked at Tuffant rims? SHOP | TuffAnt
    They will fit, they are in stock in Australia, they have various colour options, and two different styles (Kimberley and Simpson).
    2014, MY14 Discovery TDV6, Fuji White (2018-Now)
    2003, Discovery 2a, Td5 Manual, Zambezi Silver (2012-2018)
    2007, Adventure Offroad Campers, Grand Tourer (2015-Now)
    Jan 2014
    Perth Western Australia
    I have just got in a set of MOAB 18" wheels (from 4WD1 over east) which will go on one customer's disco at some point, the finish is perfect and they use the original Land Rover wheel lugs. Other 18" I have fitted, the wheel lugs simply dont seem to match the thread or likely the pitch of the Land Rover stud and there seems to be a lot of wobbly free play as you screw them on.
    Daz
    NSW SW Slopes
    My son with a D4 likes his LT265/60R18 Maxxis AT811.
    NSW SW Slopes
    Quote Originally Posted by DazzaTD5 View Post
    Likely junky nuts rather than wrong pitch. I have a spare set for last resort use only.
    Jan 2014
    I have lots of customers running BFG all terrains on their D4 most swear by them. I understand in general they are a pretty tough and can be a good pick for up north of W.A but I do note they dont seem to balance up the greatest and as they dont have as much sidewall flex they arent the best sand tyre.
    Again a high percentage of customers run Yokohamma Geolander GEO15, i run these myself and think they are an awesome tyre.
    Daz
    North Avoca
    Quote Originally Posted by kelvo View Post
    Thanks for that.
    I had checked (even though I'm loath to buy Chinese made) and the Kimberley doesn't come in a spec that will fit a D4. The Simpson has an Offset of +44 which presumably could fit but they only have five in stock and I want six.
    But, amazingly, it seems I can import six Diewe rims from the UK in time and cheaper after accounting for freight.
    My major concern is that the Diewe rims have an offset of +45 whereas Tombie tells me that the original D4 rims have an offset of +53. So I don't know at this stage whether they will fit around my calipers or not.
    Mellow Yellow
