I have done this twice, once in 2010 and again in 2020 using the Exmoor Trim Kits. I don't like doing upholstery so took the slow approach.
First one I did not have video to watch only printed word and photos, second time had videos to watch.
Just check the next stage each time particularly when it comes to the gluing bits.
The glue the first time was easy to use as it was not fast setting. The second time I could not buy what I wanted and settled on, as far as I was concerned, the wrong glue. Very limited supply of this stuff in my rural area.
So the glue NOT to use is 3M Foam Fast 74. The description on the lower part of the tin high lighted in orange said it all. Strength "High", Speed "Fast".
If the same brand had high lighted Strength "Med or High" and Speed "Slow" it would have suited me much better.
The day was a bit warm so the glue stuck FAST so I was pleased I had a reasonable idea of what I was about to do.
I have been pleased with the end result both times.
When it came to be time to do the headlining and seats in the 1954 Citroen I restored, I had no intention of doing it myself.
I did do all the sound proofing and carpets.
Someone who comes recommended by car club members is not always the best, so I found out.
Andrew
