Results 1 to 9 of 9
Thread: 98 3.2 V6 Rodeo Engine running but no pulleys moving..
    Jun 2018
    Redesdale
    Hi all,
    I'm sure most of us have had one in the family at some stage so hopefully someone can enlighten me.
    I've recently bought a relatively cheap rodeo from my FILs good mate it's a little rough looking but overall it's a good runner. I've had one in the past that was not so good to compare it to, so I'm quite happy with my purchase.
    Although I've had no problems with temp I've just started to give it a radiator flush and refill as its pretty dirty looking in the system and it only had water of course. Pour in some flush and start it up, viscous dosnt fire up straight away which I've been noticing over the last week or so.
    Go have a look and it's actually the entire belt pulleys etc nothing's moving with any force, I could stop the whole belt by hand. Engine runs fine dosnt miss a beat, after a minute or so it all kicks in like it should. Pretty sure the viscous fan is locked on also though.
    So my question is does the HB have a clutch of some description? I've noticed that the HB come with a woodruff key of sort online, does it float freely or could it have snapped causing it to? Dunno I've never seen it hopefully someone with a bit more wisdom has. Cheers
    Adelaide Hills. South Australia
    Quote Originally Posted by LRJim View Post
    Hi all,
    Hi James, this is your Mother.
    You really need to start at the first DRIVEN Pulley as you probably are aware. I would certainly suspect the Woodruffe Key has sheared off. Refrigeration compressors would do this all the time. Cause? Wear & tear & seizing of some component was usually the cause. It also may have been just loose & that will shear them so the nut needs to be kept tight.
    Hope this helps. If it does, then my BSB # is 123456.
    Sep 2010
    The Hills.
    152.79 MB
    No.
    When you stop the belt does the crank pulley also stop? If so, Des nailed it. Sheared key.
    ​JayTee
    Nullus Anxietus
    Cancer is gender blind.
    2000 D2 TD5 Auto: Tins
    1994 D1 300TDi Manual: Dave
    1980 SIII Petrol Tray: Doris
    OKApotamus #74
    Nanocom, D2 TD5 only.
    Jun 2017
    Crows Nest Qld
    I'm not familiar with the Harmonic Balancer on this vehicle, but my thoughts would be, and I have seen this on commodores in particular, that the rubber mounting on the pulley has sheared off allowing the outer to not spin while the inner is still turning.
    St Helena,Melbourne
    4.28 MB
    Quote Originally Posted by LuckyLes View Post
    The rubber bonding may have perished.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Jun 2018
    Redesdale
    Thanks all for your insights, sorry haven't had a chance to reply. It still stumps me that the HB locks in after a minute or 2 and everything works as it should, and it will work fine all day until the next morning. There must be a piece of the key floating around in the groove still and it just slips back into place after a few thousand revolutions. It still works for the time being but in the next week I'll have to fix it before it completely cacks it.
    Regarding Les and loanrangie I don't believe it's the bonding as the crank pully isnt spinning at all.
    I'll post a pic up when I pull the HB off
    Cheers Jim
    Mar 2018
    Perth (near Malaga)
    Probably the crankshaft warming up and expanding into the pulley.
    Jun 2018
    Redesdale
    Quote Originally Posted by BradC View Post
    Something similar crossed my mind but not the crank itself, I thought the key maybe or some.other phenomenon lol. But now you have said that I think i need to pull it off tomorrow at the latest, Cheers
    As the promo ditty says, "A little glue will fix it ".
