Results 1 to 10 of 12
Thread: Signal wire
    Huntly via Bendigo
    Signal wire
    I need to find a wire in the back of a D4 that is active when the ignition is on and deactivated when the ignition is turned off. I don't want to pull the insides out to run another wire for a DC-DC charger on a van and hoping to tap into an already existing wire.
    Any clues?
    Thanks Lindsay.
    Mar 2018
    Perth (near Malaga)
    I dunno about the D4, but in the D3 you can tap that off the caravan fridge fuse in the passenger side rear cubby.
    Hunter Valley
    The white trailer plug has that. It's a white and red wire
    It doesn't leak oil, Its sweating power
    Oct 2016
    Perth, AU
    2010 TDV6 3.0L Discovery 4 SE remapped to RRS output, Alaska White, GME XRS-330c, IIDTool BT, Dual Battery, Apple CarPlay, OEM Retrofitted: Cornering lights, Door card lights, Power + Heated Seats, Logic 7 audio
    Huntly via Bendigo
    Thanks for the the info will it gives me something to work on.
    Veebs that site is a pommy site, but thanks anyway.
    Lindsay.
    josh.huber Guest
    Quote Originally Posted by oldyella 76 View Post
    Lindsay.
    They are pommy plugs
    Oct 2016
    Perth, AU
    Lindsay.
    Wait till you find out where your car comes from :-)
    Dec 2011
    Adelaide
    142.79 MB
    I made up a short lead to plug a solar panel into my 12S plug. I just used an Anderson plug and 2 core cable to plug into pin 3 and 4. Pin 6 would be the wire you need and on the D3, the fuse box was in the passenger side cubby box. Not sure if the D4 has its bits in the same place. I guess I'll find out when I get my new car!
    2012 L320 Range Rover Sport Fuji White
    REMLR 012
    No 5 Trailer ARN 177-295
    2006 Disco 3, 4L V6 Petrol SE Deceased Feb 26 2023
    SOLD Engineers Trailer - no id
    SOLD RAAF 231194 Perentie 110 GS - SIR ANGUS
    SOLD 4MP COY Series 3 FFR 30-209
    Brisbane,some of the time.
    The standard cig plug in the rear area goes on and off with the ignition.
    Huntly via Bendigo
    Found a wire and then tried to get it into terminal 2 in the socket. I found the back of the 7 pin socket was filled with silicone so had to cut the wires ,lengthen the and fit a new 7 pin socket.
    Thanks all for help.
