Results 1 to 10 of 25
Thread: Repair cracked sump without removal
    Queensland
    My skidsteer has been losing a lot of oil. Its on the hoist and I found the sump has a crack about 25mm long. Its engine out to fix but thats not an option. I was thinking to use blind pop rivets to fix a plate with some Sikaflex type adhesive all around and over the crack.
    Any suggestions on what to use? Has to be heat and oil proof of course.
    Any other suggestions welcome.
    Keith
    Fuel tank repair kit?
    Sep 2010
    The Hills.
    152.79 MB
    Quote Originally Posted by 123rover50 View Post
    Keith
    Interesting conundrum. What material is the sump? One thing I would suggest is identifying the very ends of the crack and drilling a small hole there to hopefully prevent it growing, which it could do under whatever patch you use.
    Some Sika stuff is not resistant to organic oil, but their black Appliance stuff is, apparently. The big green hardware mob stock it.
    ​JayTee
    Nullus Anxietus
    Cancer is gender blind.
    2000 D2 TD5 Auto: Tins
    1994 D1 300TDi Manual: Dave
    1980 SIII Petrol Tray: Doris
    OKApotamus #74
    Nanocom, D2 TD5 only.
    Mar 2018
    Perth (near Malaga)
    I used JB Weld to patch a crack in a diff housing cover. Used a dremel to drill the end (the other was in a hole) and vee out the crack, then abrade all the area around it to ensure it had a good key. My intention was to remove the epoxy and weld it up when I had a chance.
    That was 8 years ago.
    After I posted, I did wonder about cleaning off the oil. I'm sure it would continue to weep and make it difficult to get a bond.
    Queensland
    Thanks. Good ideas there. Its thin tin stuff with indentations for strength. I was going to hit it with short blob welds with the stick so as to not get too hot. That Sikaflex sounds good. I cant clean it properly in the crack so I think the JB might not be as good for this application.These skidsteers are worse to work on than Land Rovers.
    Keith
    Mar 2018
    Perth (near Malaga)
    My only concern with that is if you can't clean the crack that when you weld it the oil will run and burn, contaminating the weld.
    Do you know anyone with a TIG? You could weld a patch over the top. Come to think of it, I repaired a hole in a steel transmission fluid line by silver soldering a patch over the top.
    I was going to suggest silver solder as it melts at a lower temp than brazing rod.
    Queensland
    Its right overhead and not much room. I might do the Sikaflex and pop rivets and see how long it lasts. Even if I get 6 months it will not be hard to clean it up and try again. Might use aluminium sheet as can mould it a bit to the humps and hollows. Got to go to town Wednesday so will visit Bunnings then. It can stay on the hoist till then.
    Jul 2011
    Yarrawonga, Vic
    if you can clean it JB weld will be with trying, I had a similar on the sump of a Dodge , The engine builder hot tanked the sump and the caustic ate the solder that sealed the dipstick port in the side of sump. He said to bring it back and he will re-solder it . I roughed the surrounding area with 40grit, cleaned it with brake cleaner and temporary smeared JB Weld & painted . Still good 4 years later.
