Results 1 to 10 of 16
Thread: Tyre Load Rating Numbers - Defender 130 Single Cab Chassis
    Apr 2014
    Hi All I am up for some new tyres and am confused about the tyre loading information on the truck. Can anyone tell me why loading has two numbers rather than one within the tyre information i.e 7.50R16 108N/116N so its the 108 and 116 that I am unsure about. Thanks!IMG_3483.jpgR
    Current : 2016 Defender 90.
    Current : 2009 Defender 130 Single Cab Chassis.
    Previous : 2013 Freelander 2.
    Previous : 2011 Defender 90.
    Previous : 2002 Discovery 2 TD5.
    Previous : 2004 Discovery 2a V8.
    Mar 2010
    victoria
    The number (108,116) refers to the load. The letter (N) refers to the speed.
    as SteveG pointed out below, N=140km
    108 = 1000kg
    116 = 1250kg
    I believe the first number is the rating when used on a 'single axle' like on your 130.
    And the second number refers to use on a double axle which is more common on trucks ie: where the axle has two tyres on the driver's side and two on the passenger's side.
    Last edited by BreakingBad; 27th March 2023 at 04:12 PM. Reason: added extra detail
    Geelong, VIC
    My interpretation of that is you can run either of those load rating tyres at those pressures.
    You shouldn’t go to a lesser load rating tyre, but can go higher.
    The N is speed rating - 140kmh
    My ‘98 130 single cab has this placard. Doesn’t mention load ratings but notes the tyres need to me able to support the max axle load.
    Steve
    1985 County - Isuzu 4bd1 with HX30W turbo, LT95, 255/85-16 KM2's
    1988 120 with rust and potential
    1999 300tdi 130 single cab - "stock as bro"
    2003 D2a Td5 - the boss's daily drive
    Mar 2010
    victoria
    Quote Originally Posted by steveG View Post
    Steve
    Apparently genuine 130 rims are rated at 2200kg to theoretically support the entire axle load on one wheel but it's hard to find a tyre that is rated at 2200kg.
    Apr 2014
    Quote Originally Posted by BreakingBad View Post
    Hard to find a tyre that is rated at 2200kg.
    Thanks for the information, my current tyres are the original Michelin XZL 116/N but 4 month wait for those so looking at alternatives.
    Apr 2014
    108 = 1000kg
    116 = 1250kg
    Thanks that makes sense, so a 114 tyre will be fine….
    Mar 2010
    victoria
    You should also consider 235/85R16
    They are usually 120Q ie: 160km and 1400kg
    And there's many more brands to choose from too.
    Apr 2014
    Yes I have been considering that option as my 90 has these. Although I do like the taller look on the 130.
    Jul 2009
    S.E.Qld
    A bit OTThis is what it says on my 7.00 16 bias belted tyres. I believe the lower rating per wheel with dual wheels is to ensure that the tyres don't come in contact with each other under any condition..W.
    Mar 2010
    victoria
    Quote Originally Posted by B.S.F. View Post
    Ha, in my earlier post I originally wrote that the lower number was for dual axles but then did a quick search to confirm but the first result said it was the other way around so I changed it.
    And that has jogged my memory. I recall reading somewhere that the lower number is used for dual axles as a kind of safety factor and is intended to limit the overall load on the double axle so in the case of one tyre failing the other tyre can still support the load. Not sure of the safety factor.
