Thread: Rear tub transom width variation
    Dec 2010
    Kiewa Valley, VIC
    The parts manual indicates that the wider body back rest panel cap pn 300865 runs up to chassis number 06110304. My 1950 has the more narrow capping, although I’m 06109984, I.e., a serial number 320 vehicles later.
    What are the chances my narrow capping is original and LR were just using up parts before the change? I understand that in the early days they were a bit ‘relaxed’ with parts as they transitioned through various changes.
    Mustlust
    1950 Series 1 80in lights behind grill
    1950 Series 1 80in rolling chassis looking for a body
    1956 Series 1 86in
    1956 Series 1 107
    1957 Series 1 88in
    1967 Mustang coupe 347 stroker
    2011 Discovery 4 3.0
    2009 110 utility 2.4tdci
    JDNSW's Avatar
    Especially if it is Australian assembled - very likely. As is the possibility that what you have is not the original tub.
    The Series 1 tub was not as durable as later ones, and it would not be surprising for it to have been replaced with a second hand one that had had less abuse at some time in the last sixty or seventy years.
    Dec 2010
    Kiewa Valley, VIC
    Can anyone confirm whether the seat base for the 80” changed at all throughout the early years. The parts book would indicate that other than the really early numbers, the seatbase design was standard throughout the 80” run.
    My query stems from wanting to know if a seat base from a 52 is compatible and a suitable join to a 49 rear tub.
    Mustlust
    1956 Series 1 86in
    1956 Series 1 107
    1957 Series 1 88in
    Queensland
    There is a difference in the centre panel cover plate for the pto. The early up to 50 had a rectangular cover plate and later 50 on had a roundish shape cover plate.
    Keith
    Dec 2010
    Kiewa Valley, VIC
    Ok, thanks Keith. So, once the seats are in, there is no physical or visual difference between the 49 and 53 seat base?
    Mustlust
    1956 Series 1 86in
    1956 Series 1 107
    1957 Series 1 88in
    Jul 2009
    S.E.Qld
    I believe that on earlier seat boxes the hinged gearbox inspection cover is riveted to the seat box and part of it. On later models 2 tabs on the cover slot into the seat box.
    .W.
    Sep 2012
    Westlake ,brisbane
    S1change.jpg S1change1.jpg From my book Land Rover the early Years by Tony Hutchings. Read top of second column about seats.
