Results 1 to 9 of 9
Thread: P38A snorkel
    P38A snorkel
    Available from TerraFirma. Probably not stocked locally but your LR parts guys could order it from their suppliers. Apparently it’s been available for the past 5 years.
    TerraFirma TF159
    TF159 - Snorkel Kit
    Jan 2016
    Netherlands
    I have that snorkel laying around for 3 years now, never got around to cut into the fender and fit it. Anyone have any questions about it, shoot!
    -P
    Mar 2024
    Italy, Roma
    I adapted a defender 200Tdi snorkel (left side) you drill the mudguard and you get to the filter box with a flexible hose
    Jan 2016
    Netherlands
    Right, reading is hard. (hence the edit)
    Anyway, still not mounted but perhaps this summer finally!
    I was not aware that defender snorkels would line up? Have any pics?
    -P
    Mar 2024
    Italy, Roma
    for the defender snorkel, you have to build the internal part of the mudguard from scratch, the original one has a wrong fold. I don't have photos, I would have to dismantle everything
    the external part adapts as a body curve, as long as it is from the 200Tdi, which mounts it on the left (I have left-hand drive and left-hand filter box)
    to get an idea of ​​the interior you can see the site Lucky 8’s Project P38 - Land Rover Forums - Land Rover Enthusiast Forum,
    at page 12, you will find how to assemble the internal part
    Last edited by V8Ian; 26th March 2024 at 09:27 PM. Reason: Hopefully fix the link.
    Mar 2024
    Italy, Roma
    questa è la parte esterna
    Mar 2024
    Italy, Roma
    non è mio, l'ho detto così
    Jan 2016
    Netherlands
    Ah yes! I remember seeing that setup way back. I reckoned the air inlet hosepipe was way too thin in diameter for a 4.6L V8 to breathe properly. Thing is, the same can be said for the terrafirma solution since the plastic is rather thick the inner diameter is not really that big. I might eventually go for one of those 4" big pipes, custom made. I am also considering moving the EAS stuff so that the air intake does not have to skirt the fender or has to be routed internally.
    -P
    Feb 2010
    Townsville, QLD
    A 4” Stainless snorkel is what I run. I considered a 3” one, but I don’t want to smoother it, so I had one made up locally at a boilermaking shop.
    4” Stainless Steel
