Any one of these from a Ford dealer will also work.
1481081
2S6T432A98AE
2S6T432A98AF
 Fossicker
						Fossicker
						Hi, my actuator has failed so I need a new one. I know the part umber is FUG500010 It seems they range from $50 to a whole lot more. What is a good reliable brand/option?
 Wizard
						Subscriber
						Wizard
						SubscriberAny one of these from a Ford dealer will also work.
1481081
2S6T432A98AE
2S6T432A98AF
2014, MY14 Discovery TDV6, Fuji White (2018-Now)
2003, Discovery 2a, Td5 Manual, Zambezi Silver (2012-2018)
2007, Adventure Offroad Campers, Grand Tourer (2015-Now)
 Master
						Subscriber
						Master
						SubscriberAs well, consider fitting an internal release mechanism. Google Land Rover Passion in Italy. I've fitted their kit. It arrived promptly, the fitting instructions are excellent and is a doddle to fit.
The benefit of having the internal release is because the end of the actuating cable can break at the 90 deg bend, so having the internal cable/release allows entry.
I got my actuator from an E-bay place in the UK and it is good, however it took 2 months to arrive. Suggest go local.
Before: Ser 2a LWB, Ser 3 S/W, 1979 RR 2 door, 1981 LR Stage 1 V8 (new), 1985 LR 110 V8 County (new), 2009 RRS TDV8
Now: MY13 D4 TDV6. "E" rear diff. Cambo's magic Engine & Auto Tune. 1968 Austin 1800 Mk1 auto (my 5th)
Here is how to get the failed one to open the tailgate...How to Open Land Rover Discovery 3 4 Locked Tailgate With Failed Actuator From Inside - YouTube by PowerfulUK. That is if running the engine, so you have good voltage and the pressing both the lock/unlock internal buttons at the same time trick doesn't work.
Alternatively, if the plastic bit on the actuator breaks LR3 LAND ROVER TAIL GATE WONT OPEN I SHOW YOU HOW TO OPEN WHEN IT IS CLOSED - YouTube
2005 D3 TDV6 Present
1999 D2 TD5 Gone
 Master
						Master
						I second the Land Rover Passion kit. When I crashed and rolled my Disco3, we crawled out via the rear widow which I opened via the passion handle from inside the car!
2012 L320 Range Rover Sport Fuji White
REMLR 012
No 5 Trailer ARN 177-295
2006 Disco 3, 4L V6 Petrol SE Deceased Feb 26 2023
SOLD Engineers Trailer - no id
SOLD RAAF 231194 Perentie 110 GS - SIR ANGUS
SOLD 4MP COY Series 3 FFR 30-209
