Results 1 to 10 of 12
Thread: Real world consumption
    Apr 2023
    Margaret River
    Hello All,
    Chasing some real world consumption figures of 265/60R18 vs 265/65R18 on a sdv6. Fuel wise.
    TIA.
    Rich
    BradC is online now Super Moderator
    No one of consequence
    Supporter
    Mar 2018
    Perth (near Malaga)
    I reckon depending on use and compound they'll do a set of tyres about every 60,000ks.
    Jan 2012
    I don’t think you’d get much difference in fuel use between those 2 tyre options…probably a greater impact depending if you’re listening to AC/DC or Beethoven.
    Apr 2023
    Margaret River
    Sorry should have specified fuel consumption
    Supporter
    Mar 2018
    Perth (near Malaga)
    We know, but it's a "how long is a piece of string" question. Aside from any change in frictional losses due to tread footprint and inertial loss due to rotating mass, there would be SFA real world difference. It still takes the same amount of energy to accelerate the vehicle mass. The vehicle still has the same wind resistance, so aside from minor bordering on irrelevant changes to gearing I'd wager AC/DC would use more fuel than Beethoven because you'd be inclined to be a bit heavier on the loud pedal.
    You're talking a 3.3% difference in rolling circumference (2433mm vs 2517mm)
    Edit: and it'll ride 14mm higher.
    Apr 2023
    Margaret River
    Haha love it.
    Yah that kinda what I was thinking.
    After the last car and bigger tyres I’m missing rubber…
    josh.huber Guest
    Getting the spare in the hole might be an issue.. Someone on here would have listed it as an issue in another thread
    Apr 2012
    Whyalla, SA
    I’ve had both. The larger being slightly more aggressive.
    I’ll be going back to 60 profile next set as I’ve seen no real offroad gain, however economy, handling and acceleration are all marginally impacted with the 65 profile.
    For record dropping my vehicle 15mm at highway speed gains me 0.5l/100km - but then a moderate/decent bump will have the rear tyres hit under the guards.
    Apr 2023
    Margaret River
    Should have mentioned spare will be on the rear bar.
    My main reason for wanting to go up a size is having a bit more sidewall and ‘bag’ out when off road. I’m finding the combo of air suspension and smaller tyres rather firm off road.
    But from what I’ve heard and you lot are saying is there is not much to be gained from going to a 65 profile.
    Rich
    Oct 2016
    Perth, AU
    I’m running the 265/60 r18 size, and find it softer than the stock 255/55R19.
    Fuel is up a bit, but I put that down to more in the car (set up for a big camping trip), knobbly tyres, a bit taller so more drag, taller gearing in stop/start traffic, wet weather vs summer, I could go on. Going to 65 profile would just be one more factor I think.
    We went with the 18” in order to get a more common tyre size when remote, however didn’t really have a drama with the 19”. The extra sidewall is nice, but not essential by my measure, but then I am a fairly sedate driver in the rough stuff…
    2010 TDV6 3.0L Discovery 4 SE remapped to RRS output, Alaska White, GME XRS-330c, IIDTool BT, Dual Battery, Apple CarPlay, OEM Retrofitted: Cornering lights, Door card lights, Power + Heated Seats, Logic 7 audio
