Results 1 to 3 of 3
Thread: D1 R380 gearbox oil cooler
    Apr 2023
    nsw
    Hi all,
    does anyone know if Australian delivered d1's were fitted with oil cooler on the later R380 equip vehicles?. I have found the adapter online but at around 700-800 dollars is cost prohibitive. Has anyone used the ashcroft adapter?
    Apr 2018
    Adelaide
    R380 oil cooler
    As far I know Australia didn’t come with gearbox oil coolers. TD5 had a pipe which was as much use as a chocolate fire guard). Others on here may have more correct info on that regard.
    I bought and have fitted the AshCroft R380 oil cooler. Had it fitted over a year ago now. Seems to have worked fine. I have had no issues with it. But I had to locate the cooler below the A/C condenser on mine so had to cut away the bottom of the front grill surround as I wanted it in the direct air flow.(pic attached). If you don’t have A/C it should go in front of the radiator between the cross supports. Where ever you put it you will need to fabricate a mount for it. have touched it after use and the cooler was warm to the touch but not hot or cold, so it was doing something.
    Sep 2010
    The Hills.
    152.79 MB
    Mine had one, but I think it was a retrofit. I don't have the adaptor any more but the cooler itself is still there, and the lines. I could probably take some pics if it helps.
    ​JayTee
    Nullus Anxietus
    Cancer is gender blind.
    2000 D2 TD5 Auto: Tins
    1994 D1 300TDi Manual: Dave
    1980 SIII Petrol Tray: Doris
    OKApotamus #74
    Nanocom, D2 TD5 only.
