Originally Posted by
Sol
Hello
Just wondering if anyone has successfully disassembled and reassembled the front bumper - namely separating the painted section from the unpainted lower section and then successfully reassembling it. If so, how? Bumper is already off the vehicle.
I can't answer your question definitively but I've had mine off recently and need to take it off again soon (to repair a slightly bodged hidden winch installation). I had a look at this too - it seems that in some places the tabs are passed through the other section and then melted on to bond the sections together. It's polypropylene so presumably if you melt too much material off to separate the two, you can weld (/melt) some more back on to put it back together again... not sure if that helps much.
I will probably have mine off this weekend so if I come up with anything I'll come back and post here.
David
Everything is easy when someone else is doing it
MY14 SDV6 SE Corris Grey
Compomotive 18s : D697s : Traxide DBS : LLAMS : ARB compressor : IC-455
Rhino Platform : GOE compressor, Tx & front bash plates, deluxe sliders
