Results 1 to 6 of 6
Thread: Hydraulic suspension pump (MG)
    Brisbane, Australia
    Good morning,
    My son has recently bought himself a project car, I think its about 2000 model MG centre engine coupe
    which has hydraulic suspension like the Minis and Austin1800. Which has collapsed.
    Does any one on the forum know where we may hire a pump and get this service provided.
    The car is not drivable at this stage, basically sitting on the ground.(Albion, Brisbane.)
    Thanks.
    Sep 2010
    The Hills.
    152.79 MB
    Hydragas?? Rimmers in the UK can probably help. Can't think of anyone local.
    ​JayTee
    Nullus Anxietus
    Cancer is gender blind.
    2000 D2 TD5 Auto: Tins
    1994 D1 300TDi Manual: Dave
    1980 SIII Petrol Tray: Doris
    OKApotamus #74
    Nanocom, D2 TD5 only.
    Nov 2018
    Hobart, Tasmania
    Quote Originally Posted by poundsterling View Post
    Good morning,
    Thanks.
    The Minis/1800/1100 only used a mixture of water, anti freeze (glycol) and a smidgen of meths pressurised to, from memory, about 220psi. I reckon an MY2000 MG would have more sophisticated mixture and use a different style of pressure/air evacuation pump? Also possibly a higher pressure?
    Before: Ser 2a LWB, Ser 3 S/W, 1979 RR 2 door, 1981 LR Stage 1 V8 (new), 1985 LR 110 V8 County (new), 2009 RRS TDV8
    Now: MY13 D4 TDV6. "E" rear diff. Cambo's magic Engine & Auto Tune. 1968 Austin 1800 Mk1 auto (my 5th)
    Brisbane,some of the time.
    MR Auto did a lot of work on Minis back in the day,so may be helpfull.
    That is where the M came from in their name,Mini /Rover.
    The system in the MG F etc is not the same as the old 1100 etc - it is an updated (different) system as fitted to the Austin, MG Maestro of the 90s.
    The last of the MG Fs (TFs?) had coil springs.
    Mar 2012
    Contact the MG Car Club - Home
    Always very good technical support. You can swap out the gas suspension for the later coil units.
