Results 1 to 10 of 12
Thread: 4hp22 operating temp
    Jun 2013
    Universe A
    Recently decided to pull down an auto box that we got in a wrecker we bought years ago that had a "failed transmission" the torque converter was badly damaged, probably from a flex plate failure.
    But I think it might have got a bit hot as well...
    No need for the Ashcroft sump sticker for temps on this one!
    99.87 MB
    This is why they are "Sealed for Life". You don't need to see this stuff.
    Slunnie
    shayne86 Guest
    Bloody hell!
    May 2003
    On The Road
    Just to add some "more" ZF goodness.. My 8speed runs at around 5deg warmer than the coolant, so nearly always above 100degC, towing, not towing, Sport or Drive doesnt seem to make any difference...
    Great Pic!!
    Oct 2011
    Fremantle WA
    Great Pic!!
    from Ashcrofts
    Automatic transmission oil can provide up to 100,000 miles of service before oxidation requires replacement, at an operating temperature of 79°C. Above this temperature, the oil oxidation rate doubles with each 11°C increase in oil temperature. See chart below.
    DEGREES F / C
    MILES / Km
    DEGREES F / C
    MILES / Km
    175 / 79
    100,000 / 162,500
    295 / 146
    1,500 / 2,438
    195 / 90
    50,000 / 81,250
    315 / 157
    750 / 1,219
    215 / 102
    25,000 / 40,625
    335 / 168
    325 / 536
    235 / 113
    12,500 / 20,313
    355 / 179
    160 / 260
    255 / 124
    6,250 / 10,156
    375 / 191
    80 / 130
    275 / 135
    3,125 / 5,078
    395 / 202
    40 / 65
    Note:
    Transmission oil and filter should always be changed more frequently when driving with heavy loads (RVs), typically at least every 25,000 mile intervals, since converter outlet temperatures then normally far exceed the ideal 79°C.
    NSW far north coast
    Quote Originally Posted by gavinwibrow View Post
    from Ashcrofts
    DEGREES F / C
    MILES / Km
    DEGREES F / C
    MILES / Km
    175 / 79
    100,000 / 162,500
    295 / 146
    1,500 / 2,438
    195 / 90
    50,000 / 81,250
    315 / 157
    750 / 1,219
    215 / 102
    25,000 / 40,625
    335 / 168
    325 / 536
    235 / 113
    12,500 / 20,313
    355 / 179
    160 / 260
    255 / 124
    6,250 / 10,156
    375 / 191
    80 / 130
    275 / 135
    3,125 / 5,078
    395 / 202
    40 / 65
    Note:
    The 8 speed runs a full syn oil from the factory so 100* is well within it's operating range, whereas the old Dexron II/III oils were straight mineral oils so you needed to keep the operating temps under control to minimise oxidation.
    Of course it's not just the oil that cops a flogging with higher temps.
    The viscosity reduces so the fluid film is thinner, and elastomers, eg. seals and O rings start to harden/prematurely age with higher temps.
    That photo above in the first post though is a cacker!
    Jun 2013
    Universe A
    Great Pic!!
    That sounds really warm to me, as Rick has pointed out, it's not just the oil that is an issue.
    Are you getting any flaring or shuddering with the converter locked?
    I've logged our 6hp and we work it hard, it'll easily hit those temps towing... And then some, but when just cruising on the highway at 110 km it's probably in the 80s.
    Jul 2021
    mandurah wa
    HI all on the subject of temperatures anybody know the thread of the bolt/plug that are next to the transmission lines - I hear this is a good spot to fit a temp sensor, any research has come up empty on this ??
    Mar 2016
    Adelaide
    Really sorry guys but I don’t know that much about auto internals. I used to do the trans filter and oil in the D2 but I haven’t in my 3.0.
    What am I looking at in the pic?
    "Land Rover - making mechanics out of everyday motorists for nearly 70 years"
    Jun 2013
    Universe A
    Quote Originally Posted by John_D4 View Post
    I'd you are referring to the pic I posted, it is of a 4hp22 with the sump off, the protective "sheath" on the wiring has got so hot it's melted.
