Results 1 to 10 of 18
Thread: OBD Diagnostic Tools
    Sep 2014
    Nornalup
    8 yeasr ago when I bought my Disco, there were only a few diagnostic tools on the market. Islander, Hawkeye etc etc.
    Now there are zillions. Even some tailored to Landies are only $200 according to one advertiser on this site. It seems they charge double for a brand specific one
    My assumption is that a specific tool will tell you that "the doodad on the whatsit" is playing up, whereas the generic version will still read the fault but only spew out a code and you have to find out what it mean? Am I correct?
    Some $50 ones such as Ancel are getting very positive reviews. I even see what looks like rebadged ones on Repco and Supercheap sites.
    My Disco is starting to show its age and I need to do more maintenance myself. I'm capable of doing most repairs so long as I know what the problem is. Once you know the parts you need, buying them fro the UK is a huge saving. Seems most repairers here put 100% markup on the same imported stuff.
    Thoughts please on the latest generation of OBD tools!
    Boggs
    14MYD4 HSE SDV6
    Active Rear Diff, Snorkel, Outback Wheel Carrier, Outback Fuel Tank, OL BullBar, LLAMS, Fyrlyt, Domin8r Winch, Drifta Drawers, MSA Drop-slide, Frontrunner rack, Cargo Barrier, Starlink Mini, Traxide.
    "The North Remembers"
    Mar 2016
    Adelaide
    An iid Bluetooth will do pretty much anything that you’ll ever need to. I’m very happy with mine
    "Land Rover - making mechanics out of everyday motorists for nearly 70 years"
    Jan 2012
    I think most see the GAP iid tool as the gold standard. I have one and cannot fault it. I haven’t played around as much as others on here, but it is comforting to know that it is the most “capable” tool available.
    Mar 2016
    Adelaide
    If you do get an iid, buy a 30cm extension cable from eBay and you can leave it attached permanently. You just need to click on ‘disconnect’ before closing the app. Otherwise the iid will flatten the car battery.
    Mar 2018
    Perth (near Malaga)
    Quote Originally Posted by John_D4 View Post
    I've found with more recent firmware (like any in the last 3 years) as long as your phone goes out of bluetooth range of the dongle it all disconnects itself. The App complains when you re-open it, but I haven't had a flat battery unless using the IID dash / SWC interface and forget to turn it off before stopping the car. I no longer use that.
    Mar 2016
    Adelaide
    Quote Originally Posted by BradC View Post
    I did not know that. Not sure if I’m going to test it tho OBD Diagnostic Tools
    Mar 2018
    Perth (near Malaga)
    I never tested it deliberately, but I can count on more than the digits I have available the amount of times I've left the car having forgotten to disconnect the phone (I use live view pretty much any time I'm going more than 5 minutes down the road).
    Jun 2015
    Darwin, NT
    Also very much interested in this. Would love to have a decent dash display of a few different temps and if possible economy info (L/100) etc.
    Looking at replacing the head unit etc with an Android unit if I decide to make it permanent but would love some input on obd units and/or apps suggestions.
    74andy Guest
    Obd2 australia scanner - anyone tried?
    Anyone had success with this one?. Land Rover OBD2 Scan Tool Full System – OBD2 Australia
    thinking harder about getting a scanner after 3 amigos appeared on trip to cape York last month - could have done with traction control a couple times, wondering if I could have diagnosed and fixed/got part sent if I had a scanner..
    Also tempted just to try this one and return it if it doesn’t work https://www.jaycar.com.au/obd-ii-eng...rchText=Pp2147
    74andy Guest
    Bluetooth Obd2 gadget
    Quote Originally Posted by DFender View Post
    Like this with display on phone? 404 Error Page | Jaycar Electronics
    Would depend on an app being available..
