Results 1 to 8 of 8
Thread: Trying to run an external SSD on a 12V TV
    May 2003
    On The Road
    The TV has twin USB ports but will only supply .5A each...
    I was pretty sure that the SSD would not draw that much---
    but while the TV recognizes it correctly it wont run it..
    I can buy a USB splitter that has two male ends and one female socket--
    will that provide 1amp?
    funnily enough the exact same TV in the bedroom runs an external 3.5HDD....
    Apr 2012
    Whyalla, SA
    Either a splitter or externally powered hub
    May 2003
    On The Road
    So I borrowed a powered hub and it just says theres an "issue" with the SSD... but it also says theres an issue with the old 3.5HDD.. so maybe the new TV doesnt like 2TB drives???
    What century is this again??
    May 2021
    Mackay
    A lot of tellies require old scool FAT32 disk partition format, which is very inefficient on high capacity drives. Perhaps switching to thumb drives or casting using something like a google chromecast would be an alternative solution?
    May 2003
    On The Road
    Yea, formatted the ssd to exfat.. windows doesnt have fat32 anymore.. I should get a response back from customer service today..
    Apr 2016
    Country Vic.
    ... windows doesnt have fat32 anymore..
    This is only because the drives you have attempted with must have been greater than 32Gb in size.
    The option is still there once you get a drive 32Gb or less.
    The way it(windows formatting) works is that the option allowed, depends on the size of the drive inputted.
    So if you have a 2GB or less(maybe 4Gb) storage of some type, you see the FAT option too.
    Arthur.
    '03 D2 Td5 Auto
    '03 D2a Td5 Auto
    May 2003
    On The Road
    2Tb
    PC60_Silicon Power Releases Its Thinnest Portable SSD Yet _ Silicon Power
    this replaces a spinning disc of the same size
    May 2003
    On The Road
    The squeeky wheel thing works!!
    After several emails to Englaon customer service( and beyond!) I was advised a nation wide "Firmware" update was being released...
    The TV now see's the 2TB SSD..
    You're Welcome fellow caravanners!
