Results 1 to 4 of 4
Thread: Vacuum Pump Oil leak
    Feb 2010
    Oil leaking from D3 Vacuum Pump drops a little bit onto the exhaust pipe Noted this almost immediately the replacement engine was installed for me. They looked and it was bounced off. Now well after the intstall and warranty period the issue has been clarified as my Vacuum Pump
    Part might be a few K? Ebay puts it at below $700???? (LAND ROVER DISCOVERY IV L319 Vacuum Pump SQJ500082 New Genuine)
    Installation is apparently difficult! Service gent suggested 2k ish giving 4 to 6,000 to repair the small oil leak.
    Not selling it with out either fixing or at least informing the people who might like it.
    Has anyone successfully replaced the Vacuum Pump themselves or have any tips? I will chat to the nice people who installed the new engine for me before I dive in to this to far
    St Helena,Melbourne
    4.28 MB
    Probably just the camshaft oil seal, pump needs to come of to fix that and doesn't look to hard to remove.
    If it is the pump i would be buying from the UK.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Mar 2018
    Adelaide
    Quote Originally Posted by NavyDiver View Post
    That pump you linked is the electric pump from the petrol engines. It sits on a mount behind the coolant reservoir and in front of the battery. If you have one of those I hope it isn't leaking oil else there is something very wrong somewhere
    For the 2.7, there is basically no room as the pump and seal are right at the back of the engine against the firewall. It isn't technically difficult, but physically it is. Our pump leaks as well, but we have the joy of the oil moving through the brake lines to the booster where it enjoys wrecking the diaphragm.
    Jun 2008
    McMinns Lagoon NT
    Yes that was causing my leak and was replaced when the timing belts were done. A little while after the oil pump
    Cheers, Dale
    'The D3' - 2006 TDV6 HSE
    Previously Enjoyed:
    2000 D2 Td5 - plus!
