Results 1 to 8 of 8
Thread: Effectiveness of Parking Brake on Steep Slopes?
    Jul 2003
    Robert Pepper discusses the improvement of parking with the Generation 2 Ford Everest whereby the centre differential can be locked when stationary minimising the potential for the vehicle to slide down a slippery slope.
    Ford Everest parks on a hill - what's fixed in Gen 2 - YouTube
    The old Defender with the centre differential locked and with the handbrake acting via the drum brake on the tail shaft has all four wheels braked.
    This got me thinking about what happens with the L663 under these circumstances given that the parking brake acts only on the rear wheels.
    Any ideas?
    Mahn England
    Ex 300Tdi Disco:
    Mar 2016
    Quote Originally Posted by one_iota View Post
    Any ideas?
    You have the rear park brake plus the transmission parking pawl acting across the attached wheels, assuming you put it into park. Stop overthinking things Effectiveness of Parking  Brake on Steep Slopes?
    2007 Audi RS4 (B7)
    May 2014
    Point Cook, VIC
    Any ideas?
    Easy to test - park it, apply hand brake, then jack up one front wheel and see if it spins.
    Apr 2016
    Quote Originally Posted by DiscoJeffster View Post
    this method still doesn't address the point that the centre diff may not be locked, so the front wheels aren't locked up with the rears. And if you place the trans in park and rely on the park pawl to hold the vehicle on the slope, you risk damaging the pawl when you try to move it into gear again! .. it's under stress.
    I had this issue on my Rodeo. Being used to half a lifetime of RRC(ie. no front locking hubs) I stupidly made my way up a 'not really' 4WD track, that quickly got very steep and needed 4WD as rear drive only wasn't making it up.
    Had to pull up to lock the hubs, but the rear only park brake did the same thing as described in the video. Rears only not enough friction to hold it on the steep hill. Didn't want to reverse back down about 100m, so I angled the ute so it would rest on the embankment to hold it on the slope, just so I could get out and lock the hubs.
    Arthur.
    '03 D2 Td5 Auto
    '03 D2a Td5 Auto
    Does the L663 have a centre diff lock or a viscous coupling?
    The L322 handbrake works only on the rear wheels and isn’t very effective - even with new disc/drums and brake shoes.
    Jul 2003
    There in lies the rub!
    AFAIK the front driveline is only engaged via clutch plates in the differential when the computer judges that drive/torque should be sent to the front. In the diesel engined L663 it is rear wheel drive until the differential is activated automatically and there is no manual locking method. So engaging the transmission parking pawl will only effect the rear driveline.
    But there might be more to it and that is why I've raised this.
    Mahn England
    Ex 300Tdi Disco:
    Jan 2014
    Perth Western Australia
    No, the old Defender (classic) with the centre diff locked and handbrake applied effectively will only brake 2 wheels (one on each axles)
    Also the transmission handbrake on all the old school Land Rovers is only average at best and should never be relied upon.
    Daz
    Jul 2003
    Quote Originally Posted by DazzaTD5 View Post
    Yes, I stand corrected.
    It's not a four-wheel drive or braked unless it has cross-axle differential locks that are engaged.
    The hand brake is particularly useless when the rear transfer box seal is leaking.
    Mahn England
    Ex 300Tdi Disco:
